Car feels wobbly (axles?) turbocharged integra gsr w/axt xtss
Somebody help me figure out what in the samhell is going on with my car. So the other day im accererating doing about 70-75mph in 3rd gear (8 psi) then all a sudden it feels like my car got a flat tire or loose lugnut or something like that and gets all wobly so im like "oh ****" and i pull over and tighten the lugnuts and check for a flat.
Lugnuts are all tight and there is no sign of a flat tire. So the next day im driving and the problem keeps happening , when i accerate past maybe 50mph the car wobbles and doesnt feel very stable, but i can still be going like 70 and downshift into 3rd and floor it but the car might start shaking as rpms build up and so does boost. The car still has all its power and the engine sounds fine so i know the engine isnt the problem.
Also, i just got an act xtss and 12.5 pound flywheel installed in addition with some new motor mounts and they have all been broken in for awhile. For those of you that dont know about XTSS , talk about a stiff clutch.
My thoughts are that its an axle, but if its an axle dont those just snap and break? im only running 8 psi. Maybe a bubble in the tire? but the tires all look fine. how much can a honda axle take? i havent had time to get it looked at yet so if anyone can help me out and point in the right direction it would be appreciated
DUSTIN
DUSTIN
Guest
Posts: n/a
Check your motor mounts. I had the same problem, which I didnt find a resolution for untill my drivers side motor mount came loose when the bolts snapped, and allowed my motor to smack down onto the axle, breaking that ****** in half.
I also had the same problem. From 50 and up the car would just vibrate to hell. I replaced the axles and the problem went away.
UPDATE
I got the tires rotated and balanced and it turns out that the tires were WAAAY out of balance. I think it may be fixed but i havent had alot of time to test it but i havent noticed the problem in the 2 minutes i drove home
bump
bump
T3T495GSR
Jul 30, 2003 02:33 PM
