Grinding sound when shifting hard???
Old Jul 27, 2003 | 07:52 PM
zuzik.2's Avatar
Default Grinding sound when shifting hard???
I have a 93 Del Sol S and when I really get on the engine, and shift into second gear, it makes a really bad grinding sound. Clutch is all the way down against the floor. It doesn't happen unless I'm really revving hard and shifting fast. Was wondering if anyone knew why or how to fix this? Thanks.
Old Jul 27, 2003 | 07:55 PM
Jimmy's Avatar
Global Moderator
Default Re: Grinding sound when shifting hard??? (zuzik.2)
Learn how to shift the correct way when going fast...or it could be a synchro...
Get it checked out
JDM_EH2's Avatar
i had the SAME problem...its ur 2nd gear syncro bearing. its a cheap fix. i took mine to a transmission place...so i can tell u how to fix it urself...but its cheap
Old Jul 27, 2003 | 08:39 PM
Malachi's Avatar
it if does it all the time then you need to think about replacing transmission parts or the whole thing, if it only does it when you're shifting like you're on crack then stop doing that. slow down, you're shifting and it may take a little while for the synchro to adjust. when you dont let parts do their job they tend to break.
Old Jul 27, 2003 | 08:45 PM
SOHC_MShue's Avatar
mind does it going into third now
Old Jul 27, 2003 | 09:33 PM
nY's FiNeSt's Avatar
try some tranny fluid first, might smooth it out alittle, but it's most likely the synchros
Old Jul 27, 2003 | 09:45 PM
EGRhatch's Avatar
Default Re: Grinding sound when shifting hard??? (nY's FiNeSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nY's FiNeSt &raquo;</TD></TR><TR><TD CLASS="quote">try some tranny fluid first, might smooth it out alittle, but it's most likely the synchros
yeah friend had the same problem, in his accord though. Tranny fluid fixed it!
Old Jul 27, 2003 | 10:30 PM
whoDAT's Avatar
Default Re: Grinding sound when shifting hard??? (EGRhatch)
yup, i agree with them...it's the synchro.
itr1244
Sep 29, 2014 12:52 PM
s2000onvolks
Jan 23, 2008 06:09 PM
rainydayman
Nov 14, 2005 07:59 AM
SLO Sol
14
Nov 12, 2005 04:59 AM
3 plus 1
Mar 26, 2004 09:07 AM
