Low Compression on motor..??
Old Aug 5, 2001 | 07:11 PM
randomwalk101's Avatar
Default Low Compression on motor..??
If your motor has low compression..say like a gsr w/ 100 psi..what is the possible problem? rings? valves??? what?? Also how much would it cost for a rebuild ?
Old Aug 5, 2001 | 09:51 PM
TurboInteg95's Avatar
Default Re: Low Compression on motor..?? (randomwalk101)
most likely rings but it could be other stuff. If the motor was that work I'd rebuild the head with new seals and guides as well as the bottom end.
shabam
Apr 17, 2007 04:58 AM
SpoolnByYou
13
Jan 4, 2007 12:14 PM
LsTurbo91
May 12, 2002 07:52 PM
