WANNA RUN A 14.9 OR UNDER>
Old Jul 27, 2003 | 04:26 AM
Quicker's Avatar
Default WANNA RUN A 14.9 OR UNDER>
I need to run a 14.9 or under in my 91 civic. what engine should I go for????
B18C1
B17
B16A2/A3
What engine would be worth droping in my civic?
Old Jul 27, 2003 | 05:50 AM
broncoman74's Avatar
From: Northwest Hills of, CT., United States of America
Default Re: WANNA RUN A 14.9 OR UNDER> (Quicker)
You can do that time with any motor, But the mods are what is going to make it happen along with proper tuning. Search around and see what people have done to their cars and make a judgement of what performance route you want to go and how much money you have to spend.
Old Jul 27, 2003 | 07:03 AM
90civichbsi's Avatar
b16a1 would get you there w/ basic bolt-ons, good tires and a good clutch
Old Jul 27, 2003 | 07:43 AM
johnzm's Avatar
Default Re: WANNA RUN A 14.9 OR UNDER> (90civichbsi)
whatever. a b16 wil require SOME skill even with boltons to run 14.9 a b18c will not u are guarranteed a 14.9 in a b18c and should probably hit closer to 14.1
Old Jul 27, 2003 | 07:50 AM
Fred n J_v2.0's Avatar
Default Re: WANNA RUN A 14.9 OR UNDER> (johnzm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">whatever. a b16 wil require SOME skill even with boltons to run 14.9 a b18c will not u are guarranteed a 14.9 in a b18c and should probably hit closer to 14.1</TD></TR></TABLE>
well, if you have a shitty driver, no times are guarranteed
Old Jul 27, 2003 | 09:38 AM
Default Re: WANNA RUN A 14.9 OR UNDER> (95VXFRANK)
i ran a 15 flat on bald tires and a crappy napa oem style clutch that kept slipping.. im sure boltons will get him there if he can drive. sure a b18c1 would guarantee it, but it would also guarantee a hole in his wallet
Old Jul 27, 2003 | 10:18 AM
TrevorHiroshima
Guest
Posts: n/a
**** the bull ****... just go h22 then... or a semi built ls/vtec
Old Jul 27, 2003 | 10:37 AM
slowman's Avatar
I took way too long
Default Re: WANNA RUN A 14.9 OR UNDER> (TrevorHiroshima)
b18c1. i hear it has some vtec action.
Old Jul 27, 2003 | 04:33 PM
xci_ed6's Avatar
Default Re: WANNA RUN A 14.9 OR UNDER> (slowman)
It shouldn't take much. You can do it with the stock engine. I remember a couple years ago somebody on resource.crx.org ran a 15 (or 16, it was like .5 sec faster than car & driver did it) flat on a bone stock CRX Si. I think it was Composimo, but i am not sure.
-Dustin
Old Jul 27, 2003 | 07:18 PM
rexer4life's Avatar
Go with a d16z6 turbo setup!!! You should pull low 14's easily with just the turbo and some type of fmu.
Old Jul 27, 2003 | 07:27 PM
Home Skillet's Avatar
If I had a chance to do it all over again I would do a B18C. I have a B16A in my 91 hatch and it can get down to 14.9 if you know what you're doing. But if you have a choice to go B18 and B16 I would have to go with the bigger brother.
Old Jul 27, 2003 | 08:17 PM
goforbroke's Avatar
MEAT PATTY
Default Re: WANNA RUN A 14.9 OR UNDER> (Home Skillet)
I'm with you HOME SKILLET, just read my sig. It is very possible though to run high 14's with a b16a and bolt ons. Even though I don't drag race its still has the potential to bust a high 14 at least with a decent driver behind the wheel.
Old Jul 28, 2003 | 12:18 AM
88rexdxa6ed's Avatar
Default Re: WANNA RUN A 14.9 OR UNDER> (goforbroke)
i ran a 15.4 in my crx mpfi converted dx with a terrible clutch and 13" steelies. now i have a 75 shot of nos and slicks, i can't wait to run it.
Old Jul 28, 2003 | 07:49 AM
BdoubleU's Avatar
Default A B16 will get you LOW 14's w/ ease.
My 90' crx DX w/ B16 runs 14.1 (aem, dc4-2-1, greddy exaust, feilds boxer)
With JDM civic R cams and slicks 13.6
Old Jul 28, 2003 | 07:54 AM
raene's Avatar
Default Re: WANNA RUN A 14.9 OR UNDER> (broncoman74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by broncoman74 &raquo;</TD></TR><TR><TD CLASS="quote">You can do that time with any motor, But the mods are what is going to make it happen along with proper tuning.</TD></TR></TABLE>
Money is no substitute for knowing how to drive Seriously. I watch people dump tons of cash into their cars, and when they bring it to the track, awww, look at the widdle ricers, they get smoked by Ford Escorts because they don't know how to handle the power.
The time in my sig was run with a stock B16A, stock timing, 92 octane gas, both seats, stripped rear interior + sound deadening, full dash, roof, sunroof, doorpanels, power door locks, power hatch, stock hood, stock crossmember, AEM CAI, Flowmaster custom 2 1/4" crush-bent exhaust, high-flow 2" cat, B&M FPR (set to stock 38psi pressure), Royal Purple 5W30 oil, Motomaster Predator 195/60R14 all-season tires at stock tire pressure (32psi), ACT HD clutch and lightened stock flywheel, with an S1 transmission. The time was run at sea level. That's it, no more mods to speak of. The car is daily-driven, right now, 1000 km's a week roughly in exactly the same trim as just stated - except I've just finished an Integra DA big brake conversion so it should be a little slower. It gets 400+ km's per tank.
B16A will get you those times and then some. It's not hard, it just takes practice.
Old Jul 29, 2003 | 10:01 PM
SiB16A's Avatar
if money wasnt a problem..Go GsR all motor youll break 13's easy...with some parts like i/h/e Clutch And good tires
Old Jul 29, 2003 | 10:10 PM
Unsung's Avatar
If you can't run a 14.9 with a b16, you have a weak motor or you suck at driving. Bang for your buck, depending on what your future plans are, the b18c5 is still the best. If you just want to run a 14.9 and be done with it, get a b16, and don't waste your money on anything else.
Old Aug 3, 2003 | 09:13 AM
0554's Avatar
Default Re: WANNA RUN A 14.9 OR UNDER> (Unsung EM1)
it all depends on what you want. i have a first gen b16a with smashed dc header, aem cold air, and str cam gears. thats its everything else is bone stock. and went 14.06 at 97.99mph at a shitty track here in portland. and thats in a 88 crx si that weighs in at 2250lbs.
Old Aug 3, 2003 | 10:50 AM
nevin's Avatar
go custom fabricated 454 big blawk monstar.. sure it will be kinda expensive but all in all its worth it
Old Aug 3, 2003 | 11:05 AM
Hybrid Invasion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">whatever. a b16 wil require SOME skill even with boltons to run 14.9 a b18c will not u are guarranteed a 14.9 in a b18c and should probably hit closer to 14.1</TD></TR></TABLE>um.... again i'm puzzled as to how anybody can't easily run in the 14's with a b16 rex. I did it the first time I ran. Not tryin to hate on anybody, but if you can't run at least 14.9 or better in a b16 crx, you really need to either A: take a hard look at your swap to see if it was done correctly, B: replace your tires(they most likely have stell belts showing), or C: learn how to drive, because it's NOT a hard goal to reach.
Old Aug 3, 2003 | 11:19 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: WANNA RUN A 14.9 OR UNDER> (Hybrid Invasion)
i ran a 14.9 in my 89 CRX with Z6, I/H/E, b16a TB, and HX wheels w/street tires, so i say its possible with a good driver and a light car. BTW mines not stripped with exception to sound deadening.
reyrey2006
18
Oct 17, 2008 10:12 PM
bangscc
Apr 26, 2006 08:06 PM
cubanbear16
Apr 25, 2006 09:27 PM
1990civichatch
Jun 17, 2004 04:21 PM
MrIllegalX
Jan 12, 2004 02:50 PM
