not starting..
Old Jul 27, 2003 | 12:32 AM
self_made's Avatar
Default not starting..
car: 01 gsr
engine: built gsr turbo
the car doesnt start, theres no spark or fuel pressure. the grounds are good. with the key in the on position, the radio works, but the dash lights dont work, nor does the vafc. any suggestions? my thought was that it was the ecu...could it be?
Old Jul 27, 2003 | 12:13 PM
slowdx's Avatar
Default Re: not starting.. (VTECNLUDE)
battery?
Old Jul 27, 2003 | 02:07 PM
self_made's Avatar
Default Re: not starting.. (slowdx)
not the battery, the engine turns over..
Old Jul 27, 2003 | 02:09 PM
acuracing's Avatar
It sounds like something electrical. Maybe your battery doesn't have enough juice at the moment to start.
Old Jul 27, 2003 | 06:41 PM
granada_sun's Avatar
check all your fuses, maybe some got wet.
Old Jul 27, 2003 | 07:09 PM
self_made's Avatar
Default Re: (granada_sun)
fuse's check out ok
Old Jul 27, 2003 | 07:12 PM
whens the last time cap n rotor were changed?
Old Jul 27, 2003 | 07:53 PM
self_made's Avatar
dont know, but it I dont think it matters seeing as how the car doesnt have power(VAFC and cluster), and how it doesnt have fuel pressure
Old Jul 27, 2003 | 11:04 PM
it just seems to be like it would be in the distributor, if the plugs arent firing, unless theres just a loose connection somewhere going to the injectors/etc....ecu bad?
Old Jul 27, 2003 | 11:28 PM
self_made's Avatar
bad distributor wouldnt explain the no fuel pressure or the vafc not getting any power
Old Jul 27, 2003 | 11:32 PM
mmuller's Avatar
Mad Scientist
Default Re: (VTECNLUDE)
have you checked your main relay?or try swapping ecu's
Old Jul 28, 2003 | 07:26 AM
JimBlake's Avatar
Someone already suggested the main relay, but have you also checked your ignition switch?
Sounds like it's closing the circuit for all the accessory things, like position I. But it's not closing the next circuit for the ignition stuff & dash lights.
ArtyTheKid
10
Sep 5, 2013 08:09 PM
Dead CIVIC
17
Mar 4, 2011 03:44 PM
j.packsb
Dec 7, 2009 08:20 AM
Syed Shah
May 29, 2007 10:03 AM
miksew
Jul 13, 2004 08:18 AM
