Can't get crank pully off!!
Old Jul 26, 2003 | 06:48 PM
xci_ed6's Avatar
Default Can't get crank pully off!!
I tried heat+PBblaster to no avail. I only heated it to ~300* F though. I had a 400lb/ft impact wrench on it too and it will not budge.
Any Ideas?????
-Dustin
Old Jul 26, 2003 | 06:49 PM
Hondasaurs's Avatar
Default Re: Can't get crank pully off!! (krustindumm)
You can always buy the tool form Honda, it's around $160, but it will work.
Old Jul 26, 2003 | 07:03 PM
1CiViC1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">I tried heat+PBblaster to no avail. I only heated it to ~300* F though. I had a 400lb/ft impact wrench on it too and it will not budge.
Any Ideas?????
-Dustin </TD></TR></TABLE>
hehe, i went thru the same problem with my hatch. Tried just about everything i could think of. Anyway a month later i took it down to a local shop where they used a 1inch drive impact, took 20 seconds .
Old Jul 26, 2003 | 07:15 PM
FourthGenHatch's Avatar
Make sure you have a good Impact with at least a 3/8 air hose, the little air hoses like 1/4 won't let the gun have enough air to be effective.
Old Jul 26, 2003 | 07:17 PM
JonGP4's Avatar
Default Re: Can't get crank pully off!! (FourthGenHatch)
man i have a Ingrsall Rand that is rated at 700 ftlbs max and it can't budge some of them. I was using a 3/8" hose and like 135PSI 20CFM? big compressor. Bottom like get that tool from honda, and a big *** breaker bar
Old Jul 26, 2003 | 07:32 PM
My 600ft-lbs Craftsman Impact with 3/8 air hose in a 15gallon compressor spun that crank bolt off with the quickness.
Old Jul 26, 2003 | 07:34 PM
y49crxsi's Avatar
I just stuck the car in 5th gear, and used a 2 ft long breaker bar and got it off. I just pushed it with my foot, while holding my self with the bumper, took no time. Must be in 5th gear though.
Old Jul 26, 2003 | 07:41 PM
xci_ed6's Avatar
Default Re: Can't get crank pully off!! (y49crxsi)
I tried it w/ the trans in 1st and my brother holding down the brakes, something was twisting, and when I let go of the bar it snapped back to the original position.
I will try it in 5th tomorrow. I also need a new starter now, it won't turn the engine over.
-Dustin
Old Jul 26, 2003 | 07:50 PM
xci_ed6's Avatar
Does anyone have a pic of this tool from honda? Will autozone carry one that I can rent?
-Dustin
Old Jul 26, 2003 | 08:41 PM
Timmah!!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">My 600ft-lbs Craftsman Impact with 3/8 air hose in a 15gallon compressor spun that crank bolt off with the quickness.</TD></TR></TABLE>
Everyone always forgets about the size of the hose. That is KEY. I have actually removed crank-pulley bolts using a 1/2 inch snap-on electric impact. Or with my 1/2 inch air impact w/ 1/2 inch hose.
Old Jul 27, 2003 | 07:07 AM
xci_ed6's Avatar
Default Re: Can't get crank pully off!! (azroth)
Well, I've got 3/8ths hose, a 1/2" 400 lb/ft wrench, and i cranked the preassure to 120 PSI. No worky. I just cracked the socket with a breaker bar though, so I guess it is time to take it to the shop.
-Dustin
Old Jul 27, 2003 | 07:24 AM
CRXNIT's Avatar
Have you tried takeing a brass punch or somthing just like it and hitting the head of the bolt. I tried this once with a stuburn bolt and it worked great.
Hit the head of the bolt real good a couple times then get that impact on there......also a breaker bar with a pipe over the end always works.
My 2 Cents.
hondachris1994
25
Dec 28, 2006 08:53 PM
torqueless
37
Nov 17, 2005 01:06 PM
spooncivic1
58
Oct 2, 2004 10:33 PM
airwalk07143
Jul 26, 2004 08:58 PM
Jamez
Feb 23, 2004 11:04 AM
