b16 axles question
Old Jul 26, 2003 | 06:02 PM
c8r9x's Avatar
Default b16 axles question
i have a 89-91 siR intermediate shaft (half shaft) and i was wondering what axles im suppossed to be using...i bought the 90-93 axles but im having problems..also what mod's if any am i suppossed to do thx
Old Jul 26, 2003 | 06:27 PM
SC0TT's Avatar
Default Re: b16 axles question (c8r9x)
Switch the SiR intermediate shaft for a 90-93 Integra (non-ABS manual trans) intermediate shaft and you'll be good to go.
Old Jul 26, 2003 | 06:46 PM
c8r9x's Avatar
Default Re: b16 axles question (SC0TT)
i also have another problem...the passanger axle doesnt go in all the way through the hub...it goes in through half way but not enough for the axle nut to screw on....any suggestions?
Old Jul 26, 2003 | 07:00 PM
SC0TT's Avatar
Did you take the dust ring off the hub? Is the axle all the way in the tranny?
Old Jul 26, 2003 | 07:05 PM
fourthgenhatchB17's Avatar
About the axle not going thru the hub ALL the way...thats most likely due to the slight rust/dirt that causes the axle to get stuck and not slide thru completely. Try spraying WD-40 inside the hub on the splines to kinda clean and lube it or u can put the axle in as far as it will go then just sit on ur *** and kinda kick with ur feet on the brake rotor or on the studs, that should force the axle thru the hub enough to get the nut started. Both of these methods worked for me.
Old Jul 26, 2003 | 07:29 PM
c8r9x's Avatar
cool i'll try that tommorrow morning cuz its 2 dark right now. does any1 know if an siR half shaft would fit into a S1 tranny? im pretty sure yes but need 2nd opinion
Old Jul 27, 2003 | 10:59 AM
Should fit fine. As long as its a B series cable tranny and B series cable tranny halfshaft, it should fit fine. It's the axles u have to worry about when changing half shafts, you have to match them to the half shaft. Check out hasport.com i think they have some good half shaft and axle info that will help u out on which axles u need for that SiR halfshaft.
Old Jul 27, 2003 | 05:11 PM
crxjdm34's Avatar
if you keep the sir half-shaft you will need 86-89 teg axles w/ 90-93 teg inner cv joints! I just went through a big ordeal w/ my car.
Old Jul 27, 2003 | 05:33 PM
c8r9x's Avatar
Default Re: (crxjdm34)
thats what i thought...im just going 2 buy a 90 ls halfshaft
Old Jul 27, 2003 | 05:44 PM
c8r9x's Avatar
Default Re: (c8r9x)
do you HAVE to take off the hub dust ring for the axle to fit all the way in?
Old Jul 31, 2003 | 07:30 PM
Default Re: (c8r9x)
Dont think u do but i "hear" it causes the axle to bind when driving with the dust ring on. Then again, i have "heard" of quite a few people leaving the dust seals on and having NO problems whatsoever. I would think it would be better for the axle itself in the long run. Try it both ways and get back to me and tell me how it worked.
Old Aug 8, 2003 | 11:04 AM
c8r9x's Avatar
alright update...i bought a 90-93 halfshaft and the axles worked fine but so that everyone knows the siR one is a little longer than the integra but just use 90-93 axles and halfshaft and no other mods are needed
Old Aug 8, 2003 | 11:34 AM
Josh717's Avatar
Get the 90-91 teg int shaft. It is stamped sk7 on it, then you can stock 90-93 non abs axles in it, andnot have to build a axle everytime you blow one.
Old Aug 8, 2003 | 11:46 AM
EFSiR's Avatar
flip the axle nut around, it'll pull the axle into the hub. THen remove it and finish the job.
stevenDAtegra
Nov 19, 2008 11:43 AM
I CRX I
May 7, 2007 07:23 PM
jacoop86
Aug 11, 2006 04:07 PM
Craigp23usa
Sep 6, 2005 06:18 PM
NINJASPY
Sep 19, 2003 02:57 PM
