SKUNK 2 TIMING GEARS NEED HELP.
I HAVE A SET OF TIMING GEARS AND MY CAR STARTED TO STALL AND IT WAS THE GEARS WHEN OF CENTER. SO I RE ADJUSTED THEM BUT MY ENGINE MAKES A FUNNY NOISE BUT STILL RUNS THE SAME ..DO U THINK I BENT A VALVE OR SOMETHING INTERNAL?
yea you prolly bent a valve. do a compression check and it will tell yaor if you dont have a compression tester. take the valve cover off and turn the crank with a rachet and listen for a hissing noise
