93 civic with 97 b18c1 obdII will it work?
Old Jul 26, 2003 | 05:42 PM
itr1235's Avatar
Default 93 civic with 97 b18c1 obdII will it work?
story goes, a friend of mine blew his civic motor. lost compression in cyl 1&4, honda wants $3100 CAN to rebuild. therefore he is going to do a swap, he found a complete 94 gsr swap in up state new york and he also found a 97 gsr swap in canada where he is situated, for a $1000 less. the question i`m asking will the
obd II motor work without any problems considering he gets all parts necessary to do the swap. any help will greatly appreciated. did a search did not find any deffinate answers
Old Jul 26, 2003 | 05:53 PM
VTECVillain's Avatar
Default Re: 93 civic with 97 b18c1 obdII will it work? (itr1235)
You can drop the full OBDII swap into the car including the engine harness and simply use an OBDI P72 ECU. It will be a direct bolt-in and mostly plug and play other than the normal wiring associated with a GSR in a Civic: add VTEC if it's not a VTEC, rewire to 4 wire O2 if it's doesn't have one, add the knock and IAB
Old Jul 26, 2003 | 07:23 PM
itr1235's Avatar
Default Re: 93 civic with 97 b18c1 obdII will it work? (VTECVillain)
it`s a 93 dx, i have read that all 92 has the vtec wires under the dash and some 93`s have them, the problem is that everyone has motors but no obd I ecu`s
nubie question what does p72 mean
Old Jul 26, 2003 | 08:39 PM
RiceNmotioN's Avatar
p72 is the ECU code for GSR ecu...every ecu has it unit codes...
p75: Ls intgera
p72: GSR ecu
P30: b16a ecu ETC.....
Old Jul 26, 2003 | 09:11 PM
itr1235's Avatar
Default Re: 93 civic with 97 b18c1 obdII will it work? (RiceNmotioN)
can i use the 97 motor but use a obd1 wire harness
Old Jul 26, 2003 | 09:23 PM
espanol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1235 &raquo;</TD></TR><TR><TD CLASS="quote">can i use the 97 motor but use a obd1 wire harness</TD></TR></TABLE>
yes
Old Jul 26, 2003 | 10:57 PM
importfan00's Avatar
Default Re: 93 civic with 97 b18c1 obdII will it work? (espano(ls))
yes
Old Jul 27, 2003 | 06:13 AM
Yes but if you reuse the OBDII distributor, injectors and alterantor they will need to be repinned/rewired to plug into the harness. You can change those parts out to 94-95 Integra OBDI parts also to make it easier.
Old Jul 27, 2003 | 01:45 PM
itr1235's Avatar
thanks
Pishpeng
Jul 9, 2007 03:01 PM
93dxb18c1swap
Oct 17, 2005 04:05 AM
00ITR-0723
Mar 11, 2004 10:07 PM
mrcivichybrid
Jan 31, 2003 07:12 PM
