Code 72, Coolant Bubbles, Fan Doesn't Turn on, Temp Gauge Way Up There, Sweet Smell from exhaust
Old Jul 26, 2003 | 04:35 PM
MikeMAN's Avatar
Default Code 72, Coolant Bubbles, Fan Doesn't Turn on, Temp Gauge Way Up There, Sweet Smell from exhaust
Well I was driving my car today, (was cool as soon as a started it) and 5 minutes later the temp gauge was WAYYYY up, all the way up to the top. I stop, pull over and let it cool. I see coolant around certain places but nowhere near the headgasket. Coolant is bubbling VERY VERY badly ,and im getting a misfire (code 72), I don't know whats goin on. Also my radiator fan doesn't go on. Im pissed cause im supposed to be going on vacation tommorow to MN. I don't think Headgasket (even tho the sweet smell) but maybe its leaking coolant into cyl 2 causing the CEL code 72? Also, the coolant is boiling when in the resivoir also.
Any help is appreciated!
mike
Modified by MikeMAN at 7:46 PM 7/26/2003
Old Jul 26, 2003 | 07:09 PM
smokey2.0's Avatar
Default Re: Code 72, Coolant Bubbles, Fan Doesn't Turn on, Temp Gauge Way Up There, Sweet Smell from exhaust
head gasket!
Old Jul 26, 2003 | 07:45 PM
MikeMAN's Avatar
yea, i figured it...****!
anyone in the midwest wanna drive here and help me install one
any temporary fixes/sealants I can put in the coolant to help it for now?
mike
Old Jul 26, 2003 | 07:53 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">yea, i figured it...****!
mike</TD></TR></TABLE>
none, just fix it right the first time before you warp the head or block
Old Jul 26, 2003 | 09:31 PM
MikeMAN's Avatar
thanks again smokey-HOMES
mike
Old Jul 27, 2003 | 05:15 AM
smokey2.0's Avatar
no problem dude, i hope everything goes well fixing your car!
Old Jul 29, 2003 | 12:36 AM
MikeMAN's Avatar
btw: would this cause the thermostat not to work + cause the fan not to run?
thanks,
mike
Old Jul 29, 2003 | 01:11 AM
smokey2.0's Avatar
the fan not working, may have been what made the engine overheat. check to see if the fan relay is working, and also check to see if the fan fuse is not blown. if those two things are in working order, give that fan 12v to see if it's not burned. if the fan works when you apply 12v to it, see if the water temperature switch is workin(may be by the water neck by the thermstat)!
Old Jul 29, 2003 | 02:23 AM
MikeMAN's Avatar
is there a chance my headgasket is fine then? only thing I am puzzled about then is why there was coolant in my engine bay? Maybe its extra that was boiling in the resivoir?
mike
Old Jul 29, 2003 | 02:24 AM
MikeMAN's Avatar
btw: how can I check the relay?
thanks,
mike
eman96
Jul 29, 2014 06:53 PM
TOO MUCH TORQUE
Jul 28, 2010 09:21 PM
bow tie
Jun 25, 2008 02:38 PM
lebowski
Jun 29, 2005 10:50 AM
LoooseGSR
Jul 15, 2003 10:49 PM
