Combustion Chamber Detonation and cost to reweld
Old Jul 26, 2003 | 01:06 PM
PopeyeTheSailorMan's Avatar
Default Combustion Chamber Detonation and cost to reweld
After taking apart a friends motor, i noticed the combustion chamber on the intake side have some rough edges that look similar to this picture i managed to find online:
Correct me if i am wrong, but will this damage to the cylinder head will need aluminium welding. The chamber port shape will need re-cutting and re-profiling and finally redecked? How much exactly does this run at a machine shop? 2 of the chambers will need reworking. Thanks.
Old Jul 26, 2003 | 01:10 PM
SiRkid's Avatar
Default Re: Combustion Chamber Detonation and cost to reweld (PopeyeTheSailorMan)
just buy a new head. they are like sliced bread
Old Jul 26, 2003 | 01:25 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Combustion Chamber Detonation and cost to reweld (SiRkid)
Just get the head milled a little and you'll be fine. That isnt bad to run it like that.
art
Old Jul 26, 2003 | 01:51 PM
Default Re: Combustion Chamber Detonation and cost to reweld (Arturbo)
Well the problem with ditching the head is that it is not a 'stock' head. Meaning it has been ported, polished, etc.
Art, are you SURE running a head like this with a pourous like area near the intake side is safe? Wouldn't this be asking for trouble considering hot spots could occur in this area? If it was on a motor pushing 8psi I wouldnt be too concerned, but this motor has pushed out 400 to the wheels and will be doing the same if not more in the near future. I'm just trying to get a ballpark figure on how much this costs to fix... hopefully we can just resurface it... but we all know when it comes to building turbo motors nothing goes as planned.
Thanks.
Old Jul 26, 2003 | 02:49 PM
SuperTeg95's Avatar
Just resurface it like Art said, or buff it with a wire brush(carefully) to smooth it out some.
Old Jul 26, 2003 | 03:59 PM
Default Re: Combustion Chamber Detonation and cost to reweld (SuperTeg95)
We are going to try to smooth it out using a dremel to just flatten out the pourous area at a very low rpm. The only concern is that the rough area has went outside the circumference of the combustion chamber by just a tiny tiny tiny bit...
Old Jul 26, 2003 | 07:44 PM
earl's Avatar
Looks like it will need to be surfaced slightly after you smooth it out
Old Jul 26, 2003 | 08:30 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Combustion Chamber Detonation and cost to reweld (earl)
Looking at that last pic it might be ok. I would take it to a professional to look at it before you attack it with a dremel.
art
jdmH2Bek4
10
Apr 2, 2012 12:13 PM
JDM_EK_JOE
Apr 20, 2006 06:33 AM
dayaftertomorrow
21
Mar 7, 2006 11:39 AM
butch11a
Welding / Fabrication
Jan 3, 2005 07:46 AM
