will 00 itr injectors fit 94 teg ls?
Old Jul 26, 2003 | 09:46 AM
rota426's Avatar
Default will 00 itr injectors fit 94 teg ls?
just as the topic says, 00 itr injectors and a 94 teg ls (b18b1) will they fit?
Thanks for any help
Nate
Old Jul 26, 2003 | 10:17 AM
timmy8151's Avatar
Default Re: will 00 itr injectors fit 94 teg ls? (styler7)
all OEM integra injectors are 240cc.
Old Jul 26, 2003 | 06:32 PM
rota426's Avatar
Default Re: will 00 itr injectors fit 94 teg ls? (timmy8151)
with the same fuel rail/block fitting? just making sure before I get them in the mail - my car has been off the road long enough
thanks,
nate
Old Jul 26, 2003 | 07:34 PM
Cyphear's Avatar
bump to a good question. I'd bet money that they will fit. If they are both 240cc, they are probably the same.
Old Jul 26, 2003 | 07:49 PM
prostreetonline's Avatar
Yes, it will work, you just need to change the injector clips.
Old Jul 26, 2003 | 10:03 PM
rota426's Avatar
Default Re: (prostreetonline)
Shiiiit I forgot about the f-ing clips. What cars can I pull the clips off of? Anyone got any?
Thanks,
Nate
Old Jul 26, 2003 | 10:16 PM
vtec.dc2's Avatar
you might not even need the clips.. you could modify obd2 injectors.. kinda make them obd1 and 2 compatible..
you have to cut around inside the harness of obd2 injectors.. i've seen it done.. but i can't guarantee everyone else won't mess up..<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prostreetonline &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it will work, you just need to change the injector clips.</TD></TR></TABLE>
Addicted 2 Adrenaline
10
Jun 14, 2007 09:16 AM
Hawks-At-Angels-12
Jul 7, 2006 02:07 PM
angela_itr
Jul 1, 2004 08:58 AM
Kevin Cliff
Jun 16, 2003 11:13 AM
99lspwr
Jun 10, 2003 03:33 PM
