weight redux in progress-need tech advice
Old Jul 26, 2003 | 04:01 AM
mycvc8u2's Avatar
Default weight redux in progress-need tech advice
93 civic cx w/d16y8
-removed ac compressor, condensor, fan and all lines and wiring under engine bay(did i miss anything else that will help save weight)????~42lbs
-removing rear bumper suport and replacing with benen strong bar~35lbs
-remove rear and pass seats when at track~45-50lbs
now?????'s
tech advice section!!
i heard that the ek's have a rear seat brace in 3 pieces when taken off and it weighs nearly ~20lbs when removed. any idea if the eg or eh's have them?? if we do have them where are they so i can remove it..
also, anyone heard of speed glass? some on e was talking about it earlier. they said it was made of lexan but much cheaper than FAL window kits. does anyone know where to get lexan and cut as well??
i am just looking to save some more weight~like 100lbs more at least.. mst ideas entertained
Old Jul 26, 2003 | 05:43 AM
skribblah's Avatar
Default Re: weight redux in progress-need tech advice (mycvc8u2)
dont forget to remove the A/c condensor under the dash ~25lbs
and the a/c bracket thats mounted to the block, thats a good 15LB peice of iron.
Old Jul 26, 2003 | 05:48 AM
mycvc8u2's Avatar
Default Re: weight redux in progress-need tech advice (skribblah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah &raquo;</TD></TR><TR><TD CLASS="quote">dont forget to remove the A/c condensor under the dash ~25lbs
and the a/c bracket thats mounted to the block, thats a good 15LB peice of iron.</TD></TR></TABLE>
i got the bracket off-yup it was pretty heavy.. the condensor under the dash?? i'm gonna have to check it out.. thanks
leew
Jul 3, 2004 11:55 AM
turbospool
May 29, 2004 05:58 PM
nexus da9
May 6, 2004 04:51 PM
STHPERFORMANCE
Feb 18, 2004 02:40 PM
mycvc8u2
46
Jul 27, 2003 06:08 PM
