Weight reduction
Old Apr 15, 2003 | 11:26 PM
turbospool's Avatar
Default Weight reduction
I know type R guys are hardcore about weight so i posted here for your help. I want to get my integra down to 94 Integra LS 2300 lbs. if possible. The following is what i have done so far:
remove ac
remove ps
remove cruise
remove antenna motor
remove windsheild wiper resevor and tubes
remove rear wiper
remove spare tire
remove tools
removed rear carpet in trunk
remove rear panel to tailights
remove rear tar
remove front tow hooks
remove all exhaust heat shields
remove whole exhuast system (open dp, not loud)
remove all four brake heat sheilds
remove front tranny and AC mounts (i have hasports replacements, these dont do ****)
few more things, but i dont remember. any more suggestions? some free weight reduction if poosible. what do you think im weighing in at right now?
things that may have added weight would be my turbo kit (rev hard 2c), i have full type R interior, dont know if thats any lighter or heavier... next i think im gonna do a RS brake line conversion and a CF hood.
Old Apr 15, 2003 | 11:33 PM
SoCal ITR's Avatar
Default Re: Weight reduction (turbospool)
Rear seat?
Old Apr 15, 2003 | 11:54 PM
turbospool's Avatar
Default Re: Weight reduction (SoCal ITR)
yea the rear seats are ITR as well, but i think they weight the same as any other.
Old Apr 16, 2003 | 12:00 AM
SoCal ITR's Avatar
Yea, I was saying remove them too.
Old Apr 16, 2003 | 12:01 AM
turbospool's Avatar
oh ok. any more?
Old Apr 16, 2003 | 12:44 AM
00 FBP ItR's Avatar
FAL windows
Remove Re-Bars, Air bags...
Old Apr 16, 2003 | 04:01 AM
Hybrid 350GT's Avatar
Default Re: Weight reduction (00 FBP ItR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR &raquo;</TD></TR><TR><TD CLASS="quote">FAL windows
Remove Re-Bars, Air bags...</TD></TR></TABLE>
Does anyone actually have FAL windows on their ITR. How well do they fit?
Old Apr 16, 2003 | 04:03 AM
1GreyTeg's Avatar
All the front tar/sound deadening,
and front firewall sound deadening,
all interior plastic,
center consoles, radio,
all seatbelts and mounts (the reels are heavy)
rear wing,
rear wiper (obviously)
and go on a strict diet...
light weight wheels are also key.
Good luck,
A.
Old Apr 16, 2003 | 04:24 AM
Track rat's Avatar
Default Re: Weight reduction (1GreyTeg)
All of the above stuff should have shed 280 - 300lbs. Then, if you are adding a roll cage, window net and harness add back 100 - 120lbs.
Old Apr 16, 2003 | 04:42 AM
Tweakmeister's Avatar
Default Re: Weight reduction (Track rat)
start digging under the dash for things to pull out
if you wanted to go really crazy you could cut out the splash reducer inside the gas tank
Old Apr 16, 2003 | 11:23 PM
turbospool's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Track rat &raquo;</TD></TR><TR><TD CLASS="quote">All of the above stuff should have shed 280 - 300lbs. Then, if you are adding a roll cage, window net and harness add back 100 - 120lbs.</TD></TR></TABLE>
you mean the mods ive done already or what?
good stuff guys, any more?
Old Apr 16, 2003 | 11:43 PM
d8168055's Avatar
read this informative article... this guy shaved 2 seconds off his 1/4 by removing some unnecessary weight... check it out! http://forums.vwvortex.com/zerothread?id=776885
Old Apr 17, 2003 | 04:28 AM
meanteg's Avatar
New User
-Airbags
-there's steel plate below the theering column, I removed it.
-carpet
-replace both front seats with lightweight ones.
-front/rear bumper reinforcements
1GreyTeg is right, light weight wheels are the key.
Old Apr 17, 2003 | 05:11 AM
len's Avatar
len
Take everything out and get the chassis acid dipped to remove all the tar. Spray some rust proofing paint on the shell. You may opt to seam weld the factory welds to increase rigidity if you'd like. Cut all the floor panels off and get some thin sheet metal to replace them. Replace your dash with an aluminum dash and door panels with aluminum sheets. Get Fiber Glass Doors, Fiber Glass Rear Hatch, Lexan Rear Glass, Fiber glass bumper, Carbon Fiber Hood, remove AC, Power Steering and I GUARANTEE YOU'LL be down to 2300LBs if not lighter.
BTW, I'm getting a 94 LS 3DR also and guess what I'm doing with it.
Old Apr 17, 2003 | 05:22 AM
Track rat's Avatar
Default Re: Weight reduction (len)
Do what Len said and you'll be WAY under 2,300. I'm at 2,350 with an empty tank and I still have a/c door, panels, center console, and a 45 lb roll bar!
Old Apr 17, 2003 | 05:52 AM
Cosworth's Avatar
Default Re: Weight reduction (DOSPOWND)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOSPOWND &raquo;</TD></TR><TR><TD CLASS="quote">
Does anyone actually have FAL windows on their ITR. How well do they fit?</TD></TR></TABLE>
Blake (pphcitr) has FAL hatch window and they fit surprisingly well from what I saw.
Old Apr 17, 2003 | 06:21 PM
turbospool's Avatar
Default Re: Weight reduction (Cosworth)
how much does the FAL hatch weigh compared to stock?
Old Apr 17, 2003 | 07:30 PM
Utilitarian's Avatar
Put your rotor heat shields back on unless you want them to warp. When water hits hot brake pads the composition will change.
Old Apr 17, 2003 | 07:32 PM
Oh yeah, assuming you have aftermarket wheels like 16s or 17s, you can save weight with race wheels like Rotas. Rotational weight saves three times the resistance of static weight.
Old Apr 17, 2003 | 07:34 PM
Rob :190:'s Avatar
light wheels and brakes will help a lot
CF hood, etc
Old Apr 17, 2003 | 11:31 PM
turbospool's Avatar
Default Re: Weight reduction (Rob :190:)
i have rota c8's all around right now. skunk2 lug nuts if those help haha.
Old Apr 17, 2003 | 11:36 PM
TypeR 599's Avatar
cut your hair.
cut your nails.
rub steel wool all over your body to take off that layer of useless skin.
knock out some teeth if you want to go hardcore
Old Apr 17, 2003 | 11:37 PM
MiraiZ's Avatar
eat celery and grapefuits for 2 weeks and you can shave about 10 pounds!
Old Apr 18, 2003 | 01:04 AM
SEFIxCivic's Avatar
Default Re: Weight reduction (BlackeR2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackeR2000 &raquo;</TD></TR><TR><TD CLASS="quote">Put your rotor heat shields back on unless you want them to warp. When water hits hot brake pads the composition will change.</TD></TR></TABLE>
bs on this one. i havent had those shields for 3 years, and lots of my friends dont have them either, my rotors aren't warped, and my brake pads are fine.
Old Apr 18, 2003 | 04:02 PM
turbospool's Avatar
Default Re: Weight reduction (SEFI8LOxCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEFI8LOxCivic &raquo;</TD></TR><TR><TD CLASS="quote">
bs on this one. i havent had those shields for 3 years, and lots of my friends dont have them either, my rotors aren't warped, and my brake pads are fine.</TD></TR></TABLE>
thats the spirit!
