How do you know when Tranny is gone?
Old Jul 25, 2003 | 07:53 PM
Xumarius's Avatar
Default How do you know when Tranny is gone?
How do you know when your transmission is gone on a manual integra?
Just out of curiosity because my teggy is kind ahigh miled and around what miles does the tranny go?
please refrain from "tranny" jokes....
Old Jul 25, 2003 | 08:30 PM
King_j's Avatar
Default Re: How do you know when Tranny is gone? (Xumarius)
when you take off, does the car move normal? or does it shake as if the clutch disc was slipping?
Old Jul 25, 2003 | 08:38 PM
Tweakmeister's Avatar
does it grind?
Old Jul 31, 2003 | 06:05 PM
SIanara's Avatar
Default Re: How do you know when Tranny is gone? (Tweakmeister)
my tranny is makin noise when i release the clutch. i had it checked out by a pro and said it was the input shaft bearing or so... beter off replacing it he said, but gsr tranny's are not cheap ... i found few that are cheaply priced with low miles... but my teg only has 81,000. however it was ripped on b4 i bought it.. i must suffer the results...(what's high milaged to you?)
Modified by GSR4340 at 8:40 PM 7/31/2003
Old Jul 31, 2003 | 07:45 PM
Default Re: How do you know when Tranny is gone? (GSR4340)
sure it's not the clutch?
anyway, your mechanic doesn't want to crack open the tranny...just like Acura dealerships. the labor is too expensive, while the part is cheap.
since you're having someone else do it, just buy a tranny. The "ultimate" is JDM ITR, with JDM final drive and LSD.
E9CiViC1F
Aug 25, 2009 02:55 PM
slammed4dreg
Feb 9, 2008 02:39 AM
integraGSR213
Sep 11, 2003 09:49 AM
ILOVEGIRLS
Feb 25, 2002 04:10 PM
