idle stuck at 3k. wtf?
Old Jul 25, 2003 | 05:47 PM
wu tang's Avatar
Default idle stuck at 3k. wtf?
ok, im not throwing any codes on my ecu. and the dam idle is stuck. how do i get rid of this? has anyone else had this problem?
Old Jul 25, 2003 | 05:50 PM
xbB's Avatar
xbB
Default Re: idle stuck at 3k. wtf? (wu tang)
Does it go back down when you apply throttle and let go?
When did it start happening?
Could be a vacuum leak or the butterfly getting stuck.
Old Jul 25, 2003 | 05:59 PM
wu tang's Avatar
Default Re: idle stuck at 3k. wtf? (CRXcellent)
um...today after i got done swapping out trannys.
Old Jul 25, 2003 | 06:03 PM
haggar's Avatar
throttle cable getting pulled/hung up on something? Vacuum line fell off somewhere? Those things could happen during a trans swap and could cause it..
Old Jul 25, 2003 | 08:58 PM
Josh717's Avatar
If you have a dashpot on the throttle body it can cause this as well, if so disconnect it and see if it lowers the idle.
Old Jul 25, 2003 | 09:27 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Default Re: (Josh717)
try checking the cruise control vacuum line on the tranny... plug it, and see if it lowers the idle.
Old Jul 25, 2003 | 11:58 PM
wu tang's Avatar
Default Re: (VashTheStampede)
ok.....it doesnt stick at 3k now, now it does the idle surge thing. 1k to 2k 1k to 2k thats how the idle is. my vacs look good though. i was thinking about playing with the idle screw. so thats what im gonna do tomorrow
boostedNOTHARDLY
Jan 18, 2010 08:07 AM
mad21kid
Feb 18, 2008 12:52 PM
toyzbus
Mar 15, 2005 11:55 AM
