Help upper control arm hitting frame on crx
Anyone have any clue to prevent upper a arm from hitting frame? I have eibach sportline springs, kyb agx struts, and dropzone camber kit. Thanks in advance
mine is lowered on neuspeed race and the top of the upper balljoint was hitting the frame... i didnt notice this until i hit a decent sized bump... i heated the frame up and pounded the **** out of it until the control arm cleared... i prob hit it in about an inch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron89 »</TD></TR><TR><TD CLASS="quote">i heated the frame up and pounded the **** out of it until the control arm cleared... i prob hit it in about an inch</TD></TR></TABLE>
This sounds like a good fix for this problem. Either that or replace the camber kit. I have the same style camber kit but my control arm doesn't hit.
welll i moved it back, and it's no longer hitting, but i think the problem is the ball joint is broken
cause with the tire on, you can tilt the wheel back and forth.
The whole thing happen when i swapped over to da brakes. I've since taken them off and put stock brakes back on. I had it aligned before i swapped to integra brakes, and never had a problem. I think the ball joint is the problem here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kincaidcrxsi »</TD></TR><TR><TD CLASS="quote">Anyone have any clue to prevent upper a arm from hitting frame? I have eibach sportline springs, kyb agx struts, and dropzone camber kit. Thanks in advance</TD></TR></TABLE>
What you have to do is cut the frame. I had an Ef before and installed ingalls camber kits in. To have the upper arm clear, you have to cut the frame. Hope that helps..
Can you adjust your camber kit in any way? My current camber kit has 2 settings, one for 3 degrees camber correction and another for a degree or so. I swapped out the kit so it would be on the lower correction side and everything cleared with a little room to spare.
jadugartir
Jan 6, 2008 12:16 PM
patastinky
Jun 17, 2003 02:44 PM
