What times should I expect on the 1/4 ?
Old Jul 25, 2003 | 12:22 PM
TyPe-R6's Avatar
Default What times should I expect on the 1/4 ?
I am entering Battle of the Imports tomorrow at MIR. I was just curious on what other R's have ran in the 1/4 with a similar setup.
Jun High Compression Pistons
DC Sport JDM 4-1 Header
Apexi N1 Exhaust
Short Ram Intake
Rota Slipstreams w/Falken Azenis
Old Jul 25, 2003 | 12:24 PM
DeL SLo's Avatar
Default Re: What times should I expect on the 1/4 ? (TyPe-R6)
13.6 @ 102 mph
Old Jul 25, 2003 | 12:26 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
High 13's, but considering the heat low 14's would be more reasonable. Considering you have high com pistons I assure the car has had other work or at least been on the dyno. Any numbers?
Old Jul 25, 2003 | 12:42 PM
JoshRambo's Avatar
Default Re: What times should I expect on the 1/4 ? (ActiveAero)
Have you run the car before? I would hope so if you are entering something. If so you should know what you will run. IF not get to the track and get your times. I am sure the times are not goignt o e the same cause of drivers.
Old Jul 25, 2003 | 12:57 PM
TyPe-R6's Avatar
Nothing else really. Port and Polished Head. It was on the Dyno when the previous owner had it. I bought car from one of the guys from SGT.
Old Jul 25, 2003 | 01:00 PM
TyPe-R6's Avatar
Default Re: What times should I expect on the 1/4 ? (Gravity)
Yes i have ran it in the 1/8...
Liquidgsr
Mar 7, 2005 04:33 AM
jdm_loser
Oct 10, 2004 01:53 PM
TyPe-R6
Jul 25, 2003 04:35 PM
2camsaam
Oct 6, 2002 10:26 AM
R0902
Jul 29, 2002 06:31 PM
