compression???????
Old Jul 29, 2002 | 11:11 AM
R0902's Avatar
Default compression???????
ok guys here's the store i was at the track las week as i posted before and didnt get the times i thought the car could do but it is not like my times were way off they were all around 15.9-15.6, i know my 60 foot ws bad 2.6-2.8 but that shoudnt make my time that bad. so anyways you guys told me to go to acura and get a compression test well i did and got 120 across the board and they said it was fine but i thought it should be higher could anyone help me out. i have a 2000 itr with intake and exhaust my next step is to dyno it to see if i have at least 163 to the wheels. thanks
Old Jul 29, 2002 | 11:13 AM
BlueR's Avatar
Default Re: compression??????? (R0902)
120 across the board???
are you sure its not 210...
Back in Black's Avatar
Rather OG
They should read twice that figure, if not more.
Old Jul 29, 2002 | 11:16 AM
Johnny Tran's Avatar
Default Re: compression??????? (BlueR)
120 across the board???...
tizzzite!!!!
ill buy the block for $1.54 (all i have in change sitting on my desk)
Old Jul 29, 2002 | 11:17 AM
Tommy_Gunns's Avatar
With a 2.6-2.8 60 ft times, I would be in the high 15's. What elevation is the track at?
Guys at 5000-6000 ft run mid 16 second 1/4 mile times in their ITR.
Old Jul 29, 2002 | 11:21 AM
R0902's Avatar
well i thought that it was very low myself and the acura service guy said he checked the book and it was supposed to be 135 and he said that his machine might have been off but as long as all the #'s are the same i shoudnt have a prob. so thenif it should be around 200 what should i do and what should i tell acura? would it affect the car and what culd happen to my engine if the red was correct and i had 120 aross the board?
Old Jul 29, 2002 | 11:28 AM
4-1-1's Avatar
Tell them to give you a new motor otherwise your car will still feel like a Integra LS........
Old Jul 29, 2002 | 11:29 AM
MPH's Avatar
MPH
New User
My compression #'s are 50, 100, 100, 100. Who has bent valves?
Old Jul 29, 2002 | 11:36 AM
R0902's Avatar
Default Re: compression??????? (MPH)
so what you guys are saying is that if my #'s are that bad then i have bent valves. i mean it goes into v-tech fine and at 6,000 but it just doesnt pull like it should when it gets there. and i just got off the phonewith acura like 5 min. ago and they said that their manual says it is supposed to be 135. so i dont know if i have a case for then to fix my car???????what should i do?
Old Jul 29, 2002 | 11:37 AM
Asahi's Avatar
2.6-2.8 will definitely be 15's. your car sound fine based on times
Old Jul 29, 2002 | 12:41 PM
98R #448's Avatar
Default Re: compression??????? (Asahi)
Go to another dealer. 120 psi across?? Your motor is @#!!??zx
try 210 and up for a stock motor. You ran a 15.6 because your car is broke. I dont even know you but you mos def. have a problem.
Dont waste yo money going to a dyno. You will never get 160hp to the ground with compression like that on a stock motor.
Old Jul 29, 2002 | 12:44 PM
jonas's Avatar
Default Re: compression??????? (98R #448)
are you stupid? 15.6 is almost impossible running 120 accross, along with a 2.8 60 foot.
Old Jul 29, 2002 | 12:49 PM
hybrider's Avatar
Default Re: compression??????? (jonas)
seriously, what kinda times do you want him pulling with that 2.8ft? oh and 120 across the board for compression? lol
learn to launch that thing, and if your still bugging over the comp #'s do it yourself !
Old Jul 29, 2002 | 12:56 PM
98R #448's Avatar
Default Re: compression??????? (hybrider93)
Jonas itr Im not stupid, I just remember when I ran a 15.6 in my itr I had problems but your right 120 across probably wouldnt pull a 15.
oh yeah cannibus got skillz.
[Modified by 98R #448, 4:57 PM 7/29/2002]
Old Jul 29, 2002 | 01:05 PM
aznmc16's Avatar
i have 160's give or take 1 on all 4 cylinders on my 94 gsr with 150k miles. good/bad? :X
Old Jul 29, 2002 | 01:48 PM
Chubz's Avatar
Default Re: compression??????? (aznmc16)
Holy ship what the fluck were those numbers 120, damn two of your cylinders wont even add togeather to make the numbers of a healthy motor. I would seriously tell acura that you car is fugged up and if its under warranty to fix it, as long as you didnt misshift or cause harm to the engine,
Old Jul 29, 2002 | 01:53 PM
happyR0072's Avatar
Default Re: compression??????? (SuperTech)
it is R0902 but i an ony do 5 post every 24 hours so i had to make a new name. i want to do compression test myself and was just wondering hw to do it, also what should i tell acura to fix? i mean they where the ones who did the test and told me everything was ok? and also i was gonna race my friend with a 98 type r with the same exact mods to see if i sty even with him
[Modified by happyR0072, 11:11 PM 7/29/2002]
Old Jul 29, 2002 | 02:56 PM
happyR0072's Avatar
Default Re: compression??????? (happyR0072)
and is it ok to drive my car until i get this fixed?
Old Jul 29, 2002 | 04:34 PM
happyR0072's Avatar
ummm?
Old Jul 29, 2002 | 04:38 PM
ITR21's Avatar
oh my 120!! a type R should be at least 210. Myne was 210 dead on all 4 cylinders and my car has high miles. There is something seriously wrong if you didnt get the numbers mistaken. You must have got the numbers mistaken. The average for a gsr is 180. your way below a gsr.
Old Jul 29, 2002 | 04:47 PM
uNF$@#!'s Avatar
my phone also goes into v-tech mode just fine
Old Jul 29, 2002 | 05:21 PM
Racebrewer's Avatar
Default Re: compression??????? (Soup ****)
My compression (properly taken on a warm engine) was 230-235 on all four cylinders. My guess is that they took the compression with the engine cold.
John
Old Jul 29, 2002 | 06:31 PM
ithrowpoop's Avatar
Default Re: compression??????? (Racebrewer)
on my gsr i had 215 across the board
Mechman456
Acura TSX
Sep 25, 2006 06:55 AM
JayLauLau
Nov 9, 2005 10:11 PM
TypeRlove
Nov 16, 2004 06:55 PM
cliff666
Aug 28, 2003 02:31 PM
