fast idle thermo valve question?
yo When you guys had a idlein problem I have done what yall told me to do. Its fixed then again not fixed im gonna change my fuel pump tomorrow 255 venom lph fuel performance pump. I fixed the idle crap somewhat but once in a while it comes right back up again like a backed up toilet when you tryin to flush your problems away. I took it to a shop all they did was open it up and wind the circle thingy back and it stoped. But every once in a while when i run it hard it does it. would a reprogrammed 5-speed do that cause it does it even on my f22a computer for the 92 accrd . It was basically doin the same thing.
So what does that mean im already changin the fuel pump tommorrow . I dont have a vaccuum leak cause i sprayed it down already no bubles check. its not the tps could it be that i need a new fast idle thermo valve cause the shop opened it up and whinned the white circle thingy on the inside of it all the way back . it stopped for a good minute but now still feelin helpless.
what should I do?
what should I do?
HGL1668
Sep 19, 2006 06:08 PM
