engine bog, ignition?
Old Jul 25, 2003 | 09:49 AM
tour de france turbo's Avatar
Default engine bog, ignition?
ok just put the b18c in and took it on a test drive yesterday. car started and everything fine. drove around for about 10 mins then finally cracked into it. thing hauled *** for about 3 runs. then when we were coming home the engine starts to sputter when you mash the gas or put it down 3/4. went home changed the spark plugs and set the fuel down a little. took it back out and it ran good for the first run. then the same problem happened. so then we though its probably the fuel, so me and my brother turned it down some more till it was running almost at stock level, 45psi. then that still dident work so we cranked it up to 60psi . after about a hour of dicking with the fuel it still wouldent fire right. the only thing i can think that would be wrong is something in the ignition. any ideas?
Old Jul 25, 2003 | 10:38 AM
Default Re: engine bog, ignition? (stock ek sleeper)
all so i just took the plugs out and cleaned them. put them back in and took it on a ride. drov egood for about 10mins then got all shitty again. my brother things theres not enough fuel going thought it, but its got 75psi going thought the pump..also the exhaust gets super super hot. i turned the car on and 1 min from idling the muffler is too hot to even touch, maybe this helos???
Old Jul 25, 2003 | 11:05 AM
SpyderZEX's Avatar
bump, because I want to know too.
Old Jul 25, 2003 | 11:18 AM
RAWB's Avatar
O2 sensor fouled?
Could also be your injectors, did you have them cleaned?
What's you timing set at?
Old Jul 25, 2003 | 07:11 PM
Default Re: engine bog, ignition? (RAWB)
injectors looked to be clean and the O2 is good, no codes. the timing is set advanced 2 i think
Old Jul 25, 2003 | 07:16 PM
mmuller's Avatar
Mad Scientist
are you serious?75 psi????. put fuel pressure back to aroung stock....and go from there, check your dizzy, maybe your ignitor might be going bad.
Old Jul 25, 2003 | 10:14 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock ek sleeper &raquo;</TD></TR><TR><TD CLASS="quote">injectors looked to be clean and the O2 is good, no codes. the timing is set advanced 2 i think</TD></TR></TABLE>
Unfortunately O2 sensor could be fouled and give "lazy" readings, without throwing a code. the only way to determine it's state would be to measure the voltage readings it gives and how fast it responces to O2 content changes, helms has instructions on the procedure.
Stan
Old Jul 26, 2003 | 12:12 AM
TIRENECK's Avatar
Default Re: engine bog, ignition? (90crxsi)
i have the similar problem,
my ecu is throwing code 4:Crankshaft Position Sensor (CKP)
Defective cicuit or unplugged/defective sensor
when you give it gas does it choke even more??
check what code the ecu blinks
Old Jul 26, 2003 | 08:18 AM
IN VTEC's Avatar
Plug wires is a good possibility. Check resistance of each of the wires or swap known good set in. The resistance will vary some b/w each wire, but shouldn't be anything outrageously out of range.
Old Jul 26, 2003 | 08:32 AM
Default Re: engine bog, ignition? (IN VTEC)
so u all dont think it could be the fuel pump? im going to check the O2 sensor tonight after work
Old Jul 26, 2003 | 08:46 AM
IN VTEC's Avatar
Still could be. If the fuel pressure isn't dropping under high load, then the fuel pump is fine.
What fuel pump are you using? B-series or D-series?
Old Jul 26, 2003 | 08:03 PM
fuel pressure is droping to 40 from 75 and its the D series pump so i think that might be it. ordered a new one today. ill se what happens with that
Old Jan 9, 2005 | 06:56 PM
dropd4door's Avatar
sounds like the same problem that happened to me when my stock dx fuel pump was on its way out, got a stock gsr one and problem was fixed right away
PaulThe
Aug 28, 2012 06:21 AM
97civic07gsxr
19
Feb 24, 2009 05:20 PM
Shaguar47
Feb 18, 2008 07:25 AM
notstock93
Sep 7, 2004 09:47 PM
