Skunk2 Manifold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midnightls »</TD></TR><TR><TD CLASS="quote">not that much, maybe like 5-10 if youre lucky. when you go FI is when it really shines.</TD></TR></TABLE>
what about when I add some Cams and ****?.
whoever you heard that from is wrong, skunk2 (ITR manifold) are good, jg edlebrock is good for much more serious applications, from 8-10k and high boost. there have been a ton of threads on this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street »</TD></TR><TR><TD CLASS="quote">What is the best intake manifold for TURBO? i have heard that skunk2 is not that good for forced induction.</TD></TR></TABLE>
STR or Venom. Something with a large plenum. If money is no object, then get the JUN manifold. It's made strictly for boost. Most serious one out on the market.
The ExVitermini skyline rocks a JUN manifold and they run 9second quartermile passes all day long.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap »</TD></TR><TR><TD CLASS="quote">
The ExVitermini skyline rocks a JUN manifold and they run 9second quartermile passes all day long.</TD></TR></TABLE>
damn! where can i find some specs and info on the jun im?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_DC2 »</TD></TR><TR><TD CLASS="quote">
damn! where can i find some specs and info on the jun im?</TD></TR></TABLE>
http://www.junauto.co.jp/
The S2 manifold is an NA manifold.. not a FI one.
Its basicly a replica of the ITR manifold but made to be bolted on a B18C1
The ITR has much more that a GSR, higher compression, wilder cams, p&p head, revs higher. Which is why it warrents a different manifold.
The engine works together as a package, you can just slap on parts randomly and expect good gains. They all have to be designed around each other.
You put on a S2 manifold with just bolt ons and you will lose low and midrange.
In my car i have gsr motor, i'm planning to change the intake manifold and throttle body. I'm getting skunk2 im and itr tb,.
so my question is, what do i need, beside gaskets and itr cable? In other words, do i still need the bracket and non gsr tb pulley? thanks...
i v o u s
Jan 27, 2005 03:31 PM
