Five lug conversion from EK
Old Jul 24, 2003 | 02:40 PM
mdj95
Guest
Posts: n/a
Default Five lug conversion from EK
Will trailing arms from EK Type R 5 lug conversion fit on EG.
Old Jul 24, 2003 | 02:43 PM
poison's Avatar
Default Re: Five lug conversion from EK (mdj95)
Depends...
what rear LCA's is he using?
The 5 lug CAN go on using your factory rear LCA's. Everything else bolts up.
Old Jul 24, 2003 | 03:06 PM
mdj95
Guest
Posts: n/a
Default Re: Five lug conversion from EK (poison)
Using CTR trailing arms on EG and factory EG lower control arms. I was told ITR and CTR trailing arms were different. I may be wrong
Old Jul 25, 2003 | 10:45 AM
nutsack's Avatar
trailing arms are the same, lca's are different.
Old Jul 25, 2003 | 01:36 PM
poison's Avatar
Default Re: (*******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ******* &raquo;</TD></TR><TR><TD CLASS="quote">trailing arms are the same, lca's are different.</TD></TR></TABLE>
Yep, you can use the CTR trailing arms, just use your factory EG LCA's.
Old Jul 26, 2003 | 01:14 PM
mdj95
Guest
Posts: n/a
Default The final specs.
Thanks guys. I have collected this info. from various members. Correct me if I am wrong. CTR and USDM ITR 5 lug conversion require 32 mm axles and will bolt to EG chassis with no problems. However, factory EG LCAs must be used. The JDM ITR 5 lug conversion uses 36mm axles. ITR LCA should only be utilized if using ITR shocks, and springs. The chassis wheel track on ITR is 10mm widder than EG. So, wheels will be pushed out 5mm more than stock track. The CTR track is 6mm wider than EG, so wheels will be pushed out 3mm more than stock. USDM and CTR front hub, caliper, and trailing arms are the same. Now, the final word. Some only recommed ITR 5 lug conversion for EG. Why?
Old Jul 27, 2003 | 11:17 AM
mdj95
Guest
Posts: n/a
Thanks! I guess I am set.
cayman_hatch
Aug 15, 2005 12:54 PM
LHC
Jun 11, 2004 07:33 AM
wizzards581
Feb 22, 2004 08:43 PM
joe_bocc
Jan 20, 2003 01:44 PM
ESCALVANTE
Nov 27, 2001 07:20 AM
