vacuum diagram fro b16 turbo set up
From: from Brooklyn NY U.S. Army recruiter in Holyoke, MA, USA
I just bought a max rev kit and I am getting ready to istall it this weekend , everything looks ok but I am confused about the fitting on top of the wastegate , I am assuming that it is for a vacuum line but have no idea where I would hook it into and also , what benefits would I get between running a dumptube or fabricating it to go into my exhaaust piping,??
dont use the top port on your WG unless you are using an elec. boost controller.
Not much benefit to dumping the WG to atmos. as opposed to back into the downpipe, as long as you put it back into the DP at about a 30 deg. angle....
