vacuum diagram fro b16 turbo set up
Old 07-24-2003, 11:28 AM
92hybridhhatch's Avatar
Location: from Brooklyn NY U.S. Army recruiter in Holyoke, MA, USA
Default vacuum diagram fro b16 turbo set up
I just bought a max rev kit and I am getting ready to istall it this weekend , everything looks ok but I am confused about the fitting on top of the wastegate , I am assuming that it is for a vacuum line but have no idea where I would hook it into and also , what benefits would I get between running a dumptube or fabricating it to go into my exhaaust piping,??
Old 07-24-2003, 11:38 AM
ykracing's Avatar
Default Re: vacuum diagram fro b16 turbo set up (92hybridhhatch)
dont use the top port on your WG unless you are using an elec. boost controller.
Not much benefit to dumping the WG to atmos. as opposed to back into the downpipe, as long as you put it back into the DP at about a 30 deg. angle....
Old 07-24-2003, 12:40 PM
Default Re: vacuum diagram fro b16 turbo set up (trboCIVIC&WRX)
OK thanks man , any more input from any of you other turbo gurus?
almostjdmeg
03-10-2008 01:00 PM
The Dirty EJ1
06-10-2007 02:31 PM
leinadmiih00
01-20-2007 04:58 PM
StockBlockRob
07-30-2004 08:34 AM
VanHonda
06-08-2003 04:01 AM
Quick Reply: vacuum diagram fro b16 turbo set up
