DX throttle problem
Old Jul 24, 2003 | 08:00 AM
Suzukablue's Avatar
Default DX throttle problem
I'm having some problems with my car going to full throttle. I try to step on my gas and really floor it but it seems that my car just doesnt want to push. I feel like there's something preventing it from speeding up. When I reach 3500 rpm, it jolts a little bit then that's when it really kicks. Any idea what might be the problem? Or is it the only capability of my slow *** motor?
Old Jul 24, 2003 | 09:00 AM
slvrcivic97's Avatar
Default Re: DX throttle problem (eg_ko_2)
i have the same thing. You can have the pedal to the floor and it doesn't have the pick up you would think it would have.
Old Jul 24, 2003 | 02:44 PM
Suzukablue's Avatar
Default Re: DX throttle problem (slvrcivic97)
when i had my 91 Si it wasnt like that. i'll floor it on first and it really kicks in. i'm thinking something might be wrong with my car.
Old Jul 24, 2003 | 02:47 PM
poison's Avatar
Sounds like you might need a tune up. Throttle cables just don't do that out of the blue.
Check your cap/rotor in the distributor, make sure you are up to date on oil changes, and check your spark plugs.
Old Jul 24, 2003 | 03:14 PM
x00gsr's Avatar
when i turn off the a/c in my dx, I get that little jolt of power too..
Old Jul 24, 2003 | 03:16 PM
Suzukablue's Avatar
Default Re: DX throttle problem (poison)
is there such a thing as the throttle cable being loose which prevents it from full throttle?
Old Jul 24, 2003 | 03:21 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_ko_2 &raquo;</TD></TR><TR><TD CLASS="quote">is there such a thing as the throttle cable being loose which prevents it from full throttle?</TD></TR></TABLE>
It's possible, but highly unlikely. You'd have to look at it and make sure the throttle cable is secure and tight on the throttle rotor.
thapimpfromchi
31
Jun 1, 2011 08:37 AM
88si
Feb 28, 2009 05:27 PM
mr poo
15
Jun 14, 2006 08:09 PM
jizzer671
Sep 21, 2005 07:07 AM
MugenHonda
Sep 27, 2002 07:40 PM
