anyone have the list of all the parts that go with Fmax?
Old Aug 4, 2001 | 09:48 AM
MiraiZ's Avatar
Default Re: anyone have the list of all the parts that go with Fmax? (puffy)
T3/T4 HYBRID TURBOCHARGER
· A/R and compressor wheel profiles can be custom made to fit order
· A Turbonetics T3\T4 with dynamic seal will come standard unless otherwise noted
DELTAGATE EXTERNAL WASTEGATE
· 9 psi. spring is standard unless otherwise specified
INTERCOOLER
· Intercooler core with 99% charge-side efficiency comes standard
AIR FILTER
· A K&N filtercharger comes standard
HKS RACING BYPASS VALVE
· Completely discharges excess boost pressure to eliminate compressor surge
FMAX HIGH-CARBON CAST-STEEL TURBO MANIFOLD
· 1 year warranty against cracking
· Available in thermocoated finish
CLOSED-LOOP MANDREL BENT DOWNPIPE
· Slip-notched closed-loop design eliminates cracking
· Bolts onto factory catalytic converter, utilizing factory exhaust donut
· 16 gauge mild steel (thermal barrier available )
INTERCOOLER PIPING
· 2" and 2.5" 16 gauge mandrel bent mild steel,
· Finish can be color matched to application, inquire for details
INTAKE PIPE
· 3" 16 gauge bent mild steel
· Maintains crank case ventilation in closed-loop operation
ERL MF2 ADDITIONAL INJECTOR CONTROLLER
· A fuel injector controller programmed to deliver a 3D fuel map, maintaining proper air fuel ratio (pump and regulator to the left, MF2 on the right)
· Delivers fuel up to 2 bar or 30 psi of boost
DETONATION MANAGEMENT
MSD-BOOST TIMING MASTER
· Eliminates detonation by retarding timing per pound of boost
. IDEALHEAD GASKET
· Eliminates detonation by lowering the static compression ratio
· Allows full ignition timing advance up to 13 pounds of boost on 92 octane
or
ADDITIONAL INJECTORS
· New Lucas fuel injectors capable of delivering fuel up to 175 additional horsepower
Old Aug 4, 2001 | 07:52 PM
DirtyLude's Avatar
There's a list with a picture of all the supplied parts here:
http://www.hondaprelude.to/articles/inst_turbo.html
mbsi
Jun 18, 2005 12:17 AM
0ptimus prime
Welding / Fabrication
10
Mar 6, 2005 06:30 PM
KYS2000
Honda S2000
24
Feb 28, 2004 12:25 PM
RedTegLS
Oct 15, 2003 08:08 AM
2K_TEG
Oct 22, 2001 12:05 PM
