how much boost can a it take?
Old Jul 23, 2003 | 08:43 PM
sikcrx80's Avatar
Default how much boost can a it take?
well as my topic says how much boost could me b16 in my crx take stock..
befor i have to lower my comp.
and what kind of power gain am i talking about?
Old Jul 23, 2003 | 09:23 PM
pissedoffsol's Avatar
25 Year Member
Default Re: how much boost can a it take? (sikcrx80)
there is no set in stone number.
its based on:
turbo size, trim, a/r, flow rating
cc of motor
cc of combustion chamber
fuel
fuel management
and a bunch of other things i don't feel like typing out.
10 psi on a t25
is not
10 psi on a t88
Old Jul 23, 2003 | 09:24 PM
InTeGrA B18b1's Avatar
20 psi tuned or 8 psi tuned your choice
Old Aug 3, 2003 | 08:18 AM
machine4321's Avatar
Default Re: how much boost can a it take? (InTeGrA B18b1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 &raquo;</TD></TR><TR><TD CLASS="quote">20 psi tuned or 8 psi tuned your choice</TD></TR></TABLE>
your joking right .....your teling him to run 20 psi "tuned" on a stock motor ??
Old Aug 3, 2003 | 09:38 AM
Diablo Tejano's Avatar
Default Re: how much boost can a it take? (machine4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">
your joking right .....your teling him to run 20 psi "tuned" on a stock motor ??</TD></TR></TABLE>
I don't think that he is. As long as the motor is in decent shape, with appropriate fuel delivery(high-flow pump, 720cc, etc) and decent management(hondata, Electromotive, F.A.S.T.etc) I really don't see a problem with 20psi. Besides, it's not like hes going to be running 20psi all the time.
Edit: Turbo selection will also affect how the motor responds to a given level of pressure. As was previously stated psi is not the same on every turbo, more importantly cfm isn't the same on every turbo.
James
Old Aug 4, 2003 | 07:59 AM
theres no way 20psi on a stock enginge will work no matter how much fuel or tunniong was used....tthe factory pistons couldnt take tha kind of heat and the rods for sure cant take the stress ...mabye im wrong here but the sounds way out of line
Old Aug 4, 2003 | 08:40 AM
DaveF's Avatar
Default Re: (machine4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">theres no way 20psi on a stock enginge will work no matter how much fuel or tunniong was used....tthe factory pistons couldnt take tha kind of heat and the rods for sure cant take the stress ...mabye im wrong here but the sounds way out of line </TD></TR></TABLE>
http://www.inlinepro.com
they love boosting stock engines down there.
Old Aug 4, 2003 | 08:58 AM
LiLOtaku's Avatar
Wich turbo do you plan on using, what injectors are you gonig to run and what kind of fuel management are you going to use, and are you going to use an intercooled setup?
These are some of the determining factors that will limit your boost. In most cases its not really the amount of psi your motor can handle, but the amount of horsepower it can handle. I'm gonig to have to say that the stock block can prolly handle up to 310hp(i have seem more though), but not constantly. I personally am going to run 10psi with a t3/t04b turbo with 550cc injectors and hondata.
550cc injectors can handle up to 325hp-350hp safely with good tuning and management
List your whole setup for us.
I'm see'ing some "odd" advice from people on this subject. Hopefully one of the guru's will pop in here.
Old Aug 4, 2003 | 09:22 AM
its not me ....its thia crx punk
but ya 20 psi it to much an a 100 pecetn stock motor ......and by this i mean last longer then a month
Old Aug 4, 2003 | 09:23 AM
Default Re: how much boost can a it take? (bluboy)
well even say 20 psi on a stock dsm turbo ....(well i know it wouldnt putt out power but you get the point ,even that is to much on stock internals
tdark1582
Apr 9, 2007 08:19 PM
vtak2nr
Jan 13, 2007 11:10 AM
BoOsTiN Dc2
Aug 6, 2005 09:55 PM
TurboEG6
Feb 9, 2004 10:41 AM
chris@allmotor.net
Sep 4, 2003 10:32 AM
