how tight should the cv joint bolt be?
Old Jul 23, 2003 | 06:57 PM
HellbillY's Avatar
Default how tight should the cv joint bolt be?
i just bought a 92 vx hatch. the seller did not disclose the tranny problems so i am swapping trannies. i have the new tranny but it seems that the bolt on th cv joint is super tight. i was able to break over the driver side, but the passanger side is hell. i do not have access to air so i am using a break over bar and i am having some one hold the brakes in. any ideas on how to get it loose?
Old Jul 23, 2003 | 09:01 PM
egcivic94's Avatar
are you talking about the spindle nut? well, the easiest way to get it loose is to break it loose while the wheels are still on. I used a old weight set bar to get alot of leverage and it should go no problem, if you already got it jacked up, stick a long screw diver or somthing of that nature inside the slot of the roter and e break it the same way, the scew criver hitting the ground will stop the roter from moving. good luck.
Old Jul 23, 2003 | 09:20 PM
Black Armada of Death's Avatar
Default Re: (egcivic94)
Yes, the nut nut on the control arm is a locknut, and thus pretty tight. Eat some spinach, and get a breaker bar.
EDIT: I didn't read the "Break holding" part. Disregard the above.
Old Jul 23, 2003 | 10:35 PM
firehouse's Avatar
Default Re: how tight should the cv joint bolt be? (HellbillY)
Why this has to be the hardest nut to take off!!! I swear someone always post how to break the nut loose. anywho, no hate here.. I had the same problem so this is what I did.
Get some W40 or Liquid Wrench and spray some on the axle nut. Now you know that the axle nut is 32mm so get a smaller socket size like 27mm and put that on top of the nut and bang it with a hammer a couple of times. This should break the nut loose. Now with a little elbow grease on that breaker bar it should come off. If it doesn't do it, repeat the procedure until that sucker comes off.
I had someone step on my brakes instead of putting the wheel back on. I wish I have pics to show you but I hope you get the idea.
i love my ef
Apr 7, 2006 10:05 PM
tuphatt
11
Sep 15, 2004 12:10 AM
enigma94
11
Jun 14, 2004 09:10 PM
VWkila
Mar 30, 2002 09:41 PM
DreamSpeed
Oct 29, 2001 04:35 AM
