anyone with an F-Max turbo kit for gs-r??
The downpipe comes with an O2 sensor holed pre-drilled...plugged with a bolt... am i supposed to relocate my stock one to that? Even though the stock sensor doesn't reach... buy a new one so i can route it there? Or is the hole there just for looks?
If so. does it matter what O2 sensor i get? name brand? (ngk) or just a 20 dollar generic do the same? i have around 85k miles... should be just about time for new ones anyways..
Thanks for the thoughts/comments.
What year is your GSR? If its OBD1, keep your stock sensor where it is. If its 00-01, you will relocate your primary 02 sensor to that bung if there is not another bung on the downpipe.
If you arent 00-01, keep the bung plugged and keep your stock 02 sensor(s) where it is.
ah okay, thanks, it's a 96' so i take it keep it where it is?
Also, another question about my air/fuel gauge.. i hooked it up to the white wire on that o2 sensor and when the car is idle.. it goes back and forth like it should.. when i drive and accel. it stays green when i accel just a little higher or get around 4k it just disappears... Could it be hooked up wrong? or a bad o2 sensor?
Thanks for the help.
at WOT it disappears also...
Fmax kit is the one they sell at turbokits.com
http://www.turbokits.com/acura_turbo_kits.html
The injector controller fried on me.. pretty lame. So i'm just gonna get a SuperVafc and some DSM 450cc injectors and do it that setup.
