help please now im going crazy!!!!!
I have a 93 ls in my 92 civic HB and the motor keeps jumping time. It jumps 180 degrees every time im go to drive drive it. it has the right timing belt and the tightner pully is good???????? so why is it jumping time helppppppp please ASAP thanks to anyone that helps me.
do you have an aftermarket cam gear? christ, if it is skippin that many teeth you can royally fawk your engine, i wouldnt drive it until you figure out whats wrong. How much play does the belt have?
Someone correct me if I'm wrong, I havent dont this in a while, but can't that happen normally, the crank be up, TDC and the cam be out of its expected phase, if you rotate the crank 360 degrees what happens to the cams?
jumping a tooth is normal from my experiences, but not a full 180(in my experiences here)... for some odd reason one thing isnt spinining correctly... its slipping real bad....
I'm telling you, your honda knows that you own someone either a set of carbon fiber tail lights or his stock, perfect condition tail lighs back... Maybe if you were to send me my lights like you were supposed to do a month ago, your car might run better, then again, I guess I'm going to have to keep posting on every thread you make about how you never sent my anything.... THanx...
Scammers suck
Scammers suck
unessacary..... but
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89dxhunchback »</TD></TR><TR><TD CLASS="quote">I'm telling you, your honda knows that you own someone either a set of carbon fiber tail lights or his stock, perfect condition tail lighs back... Maybe if you were to send me my lights like you were supposed to do a month ago, your car might run better, then again, I guess I'm going to have to keep posting on every thread you make about how you never sent my anything.... THanx...
Scammers suck</TD></TR></TABLE>
YOUR OWNED FOOL!!!!!
