Can I dyno tune gsr with drag gen 2 kit for more power?
Old Jul 23, 2003 | 02:26 PM
turboteggsr's Avatar
Default Can I dyno tune gsr with drag gen 2 kit for more power?
Been running 7.5 psi for a little over 2 years with 15 degrees timing on 100 octane sunoco race gas and was wondering if i dyno tuned it with my hks afr if i could tune some more power out of it on the same boost level. Does anyone here have any experience with my setup that has dyno tuned it-(what kind of power you got out of dyno tuning it and what a/f ratios the car made untuned?) I am planning on dynoing it regardless to see what a/f ratios i pull. I am thinking of tuning the motor for 11.8:1 a/f ratio. Someone have some advice on what a/f ratio to tune for? Any other info would be appreciated. Thanks
Setup: Stock injectors with 12:1 fmu (i think its 12:1) and the inline pump(bosch or airtex?, how much flow? anyone know?)
Old Jul 23, 2003 | 02:58 PM
Default Re: Can I dyno tune gsr with drag gen 2 kit for more power? (turboteggsr)
Anyone?
Old Jul 23, 2003 | 03:09 PM
Adriano's Avatar
just get hondata..it will help alot
Old Jul 23, 2003 | 03:14 PM
Default Re: Can I dyno tune gsr with drag gen 2 kit for more power? (brryder)
At some point that would be nice but i dont have that kind of money right now and i have had the afr for quite some time i just hadnt installed it. I do believe that i could at least do some tuning with the afr i dont believe that its hondata or nothing.
Is it impossible to tune a forced induced gsr with something as simple as an afr of afc?
Old Jul 23, 2003 | 03:20 PM
Adriano's Avatar
just get the dsm 440' injectors and the afc. that will help some.
Old Jul 23, 2003 | 03:21 PM
drvfast's Avatar
yes you can run the afc hack as a fuel managment system. get some 440's and get rid of the fmu setup. Get the car on a dyno. By the way you should upgrade to a 255lph in tank fuel pump.
Old Jul 23, 2003 | 03:26 PM
Default Re: Can I dyno tune gsr with drag gen 2 kit for more power? (drvfast)
I have the walboro 255 high pressure on order should be here soon. Is it alright to run the whinebro and the inline pump together or should i just scrap the inline pump and run the whinebro only. I will order the rc310s within maybe a month and at that point i will turn the boost up to 9 psi but i would kinda like to dyno my setup now on 7.5 psi and the only tool i have is the afr. I have heard of many people on this board running 7.5 psi on stock injectors for a long time as i have. My question is is it possible to tune with stock injectors and an afr, until i get the rc310cc inejectors. I dont mean to be a ***** and i do appreciate the advice on the 440 dsm hack but i need some guidance on what i have now. Thanks again you guys.
Old Jul 23, 2003 | 03:48 PM
thrty8street's Avatar
bump.
Old Jul 24, 2003 | 10:45 AM
How do you guys feel about the 15 degrees of static timing? Its one degree retarded. Also does anyone know whether or not this setup out of the box dynoes on the rich side or the lean side? Someone has to have dynoed this setup before. I just would like to know if it was rich enough on the top end that they could lean it out some and make some more power. Also how do you guys feel about my target a/f ratio of 11.8 or 11.9:1? Any suggesstions or advice would be appreciated it. Thanks on the injector info.
Old Jul 26, 2003 | 03:18 AM
bump
negusjuda
92
Oct 30, 2011 02:24 PM
Beckerton
Engine Management and Tuning
14
Jun 30, 2010 10:35 AM
type B16
Aug 19, 2006 07:42 AM
B18C1CYA
Jul 10, 2004 08:12 PM
2000vsm
Feb 16, 2004 01:27 AM
