Has anybody used RX7 460 injectors.....
I have a set of 89-90 RX7 460's that I'm sending out soon to be cleaned in preperation for project GSR-T... just wondering if anybody has used these in a Honda application yet. It's nice not having to worry about wiring resistor packs and the sort, saturated = plug n' play
I have been using the 460cc non turbo Rx-7 injectors now with my setup for a year. Works great. And like you said its plug in play if you have square tops. If not, u need to get the clips from the Rx-7.
are the turbo rx7 injectors 550cc? will they be able to work with a h22a? i'm gunna use a standalone to control them, but i wanna know if they can fit and what cc they are. can they feed enough fuel for 15psi?
thanks
daniel
thanks
daniel
http://www.rotaryresurrection.com/injector.html
I had them on for a while worked well just needed them cleaned and stuff and they are plug and play except something about a notch on the injector connectors signifying low or high impedence...
