Subby or Evo Turbo Injectors
I was wondering if anyone has used these injectors...the subbys wrx's are around 850cc's and the evo's are around 720cc's.....so will these fit in a honda rail & mani?
Re: Subby or Evo Turbo Injectors (drumking15)
are you talking about stock wrx/evo injectors?
cause if you are, I'm sure the wrx injectors are not 850cc.
anyhow, the wrx injectors are most likely side feed, and will not work with a stock honda fuel rail.
Re: Subby or Evo Turbo Injectors (warrick)
STI injectors are only 550 and i believe the older WRX was around 440 or sumthing like that. I had a friend just upgrade his WRX injectors to 550cc STI injectors.
The Subarus wont work, but the Evos apparently will. There have been threads on this in the past, apparently the 565s from the Evos fit just fine, just have to use resistors.
Re: (redzcstandardhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch »</TD></TR><TR><TD CLASS="quote">so the evo 565's will work with no real wiring modification (resistor wise) in an 88-91?
are the clips the same? </TD></TR></TABLE>
i believe you have to use obd1 clips....these are similar from what im told as dsm 450's...but are just bigger...
to bad 550's wont support my goals
