code 5 with boost >>>
Old Jul 23, 2003 | 08:39 AM
platinum00's Avatar
Default code 5 with boost >>>
every once and a while i get a code 5 cel.
MAP Sensor (Manifold Absolute Pressure)
mechanical problem / disconnected piping.
piping to map is hooked up correct and not leaking. does this mean my map is bad.
how does the ecu determine that it's a mechanical problem. from a invallid reading or somthing..??
platinum.
Old Jul 24, 2003 | 04:46 AM
platinum00's Avatar
Default Re: code 5 with boost >>> (platinum00)
ttt
Old Jul 24, 2003 | 05:09 AM
adhana2's Avatar
wrong forum
Old Jul 24, 2003 | 05:46 AM
devonic's Avatar
check all your vacuum connections, i got the same code, i checked all the vacuums again and none were loose but the code went away after i unplugged them and plugged them back in.
try cleaning your map sensor also, might be the connector is dirty and gives a faulty reading sometime. i know mine was dirty as hell when i was getting that code.
Old Jul 24, 2003 | 08:00 AM
platinum00's Avatar
Default Re: (devonic)
i smoke the pipe.
let me move to the right forum.
Old Jul 24, 2003 | 08:02 AM
platinum00's Avatar
Default Re: (platinum00)
https://honda-tech.com/zerothread?id=572150
eggie75
Apr 7, 2008 01:40 PM
Nextelbuddy
10
Jun 19, 2005 07:24 AM
Achenar
Oct 2, 2004 01:45 PM
909rex
Jul 28, 2004 05:50 PM
platinum00
Jul 25, 2003 09:16 AM
