EDFC With Tein SS? Yes Or No?
Old Jul 23, 2003 | 01:43 AM
integlspwr01's Avatar
Default EDFC With Tein SS? Yes Or No?
I have a 1992 Honda Civic Hatch Back. I'm currently in the process of buying some Tein SS for it. I'm buying the Acura Integra GSR Version because of the stiffer spring rate, but i'm up in the air about the EDFC System.
On Tein's Website, it says the EDFC works with the Tein SS on the Integra application. They have a different part number then the Flex EDFC counter part. I'm thinking its more clearance like everyone has been saying, but my Civic is gutted to S.hit so I'm not worried about my rear shocks have clearance problems. I'm thinking it might be the front shocks might sit too high where the EDFC controller might hit the hood.
Now when you scroll down to the EG Civic Tein SS. It says its not compatible. I thought the difference between the civic & integra system was just the spring rates. But if you move your eyes more to the right, it says the EDFC will work on the FLEX.
http://tein.com/edfc-fit.html
I'm really confused here. I really want the EDFC for my Civic Hatch. Which part number would I buy, the Tein SS for the Integra, or the FLEX EDFC for the Civic?
Bottom line, Integra Tein SS in EG6 Hatch. Which EDFC controller do i buy?
Any insight to the situation would be greatly appricated.
Thanks!
-Edgar-
Old Jul 23, 2003 | 01:46 AM
eg_type_r93's Avatar
i got ha's and edfc wont fit them so i think it wont buddy only the higher end products will get the edfc just a way to make you spend more money
Old Jul 23, 2003 | 02:16 AM
Ivan's Avatar
senior gold member
Default Re: (eg_type_r93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 &raquo;</TD></TR><TR><TD CLASS="quote">i got ha's and edfc wont fit them so i think it wont buddy only the higher end products will get the edfc just a way to make you spend more money</TD></TR></TABLE>well actually the reason it won't fit is cause it couls hit the hood. I've heard of people putting them in with mods. 96+ would be easier since theres more room cause I have a buddy that put them in with no probs or so he says
Old Jul 23, 2003 | 02:49 AM
Kamin's Avatar
Default Re: (Ivan)
the only thing the EDFC's will work on for honda's are the flex's
Old Jul 23, 2003 | 03:31 AM
Default Re: (Kamin)
If the EDFC's will only work on the Flex with Honda's then why does the Tein Website it self says the EDFC will work on the SS with the Integra application?
Anyone can explain?
Old Jul 23, 2003 | 03:33 AM
Default Re: (Ivan)
Hell, i'll cut up my hood to make the EDFC's work with my Tein SS.
Anyone care to explain more if it will or will not fit?
Thanks!
Old Jul 23, 2003 | 05:49 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: (integlspwr01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr01 &raquo;</TD></TR><TR><TD CLASS="quote">Hell, i'll cut up my hood to make the EDFC's work with my Tein SS.
Thanks!</TD></TR></TABLE>
Why for some small convience. Not worth the hassle IMO.
Old Jul 23, 2003 | 07:09 AM
Default Re: (Apex i ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex i ITR &raquo;</TD></TR><TR><TD CLASS="quote">
Why for some small convience. Not worth the hassle IMO.</TD></TR></TABLE>
It is in my eyes...
Anyone else can answer my question.
THanks!
Old Jul 23, 2003 | 02:27 PM
Ivan's Avatar
senior gold member
Why for some small convience. Not worth the hassle IMO.</TD></TR></TABLE>exactly. I mean if its too hard for someone to pop your hood to adjust your suspension, iono about you
Old Jul 23, 2003 | 02:46 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr01 &raquo;</TD></TR><TR><TD CLASS="quote">If the EDFC's will only work on the Flex with Honda's then why does the Tein Website it self says the EDFC will work on the SS with the Integra application?
Anyone can explain?</TD></TR></TABLE>
it is possible its a misprint.
you know not many people have dropped the 2000 or so dollars for a EDFC suspension.
Old Jul 23, 2003 | 02:49 PM
SpooN Man's Avatar
Default Re: (Kamin)
It will work with the ss's on a civic, BUT you cannot close the hood
I guess you could go cutting up the hood to make it fit, but the hood needs support in that area badly so it might not be that good of an idea.
It is a bad *** concept, I'd love to be ripping up gingerman and be able to adjust the suspension WHILE driving. Not having to pit to make minor adjustments.
Old Jul 23, 2003 | 03:23 PM
Default Re: (SpooN Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpooN Man &raquo;</TD></TR><TR><TD CLASS="quote">It will work with the ss's on a civic, BUT you cannot close the hood
It is a bad *** concept, I'd love to be ripping up gingerman and be able to adjust the suspension WHILE driving. Not having to pit to make minor adjustments. </TD></TR></TABLE>
thanks man for clearing that up. Do you know which model number I would have to buy so that I can cut as little off my hood?
Thanks In advance.
Modified by integlspwr01 at 2:35 PM 7/23/2003
Jatt87
Suspension & Brakes
Feb 9, 2007 02:10 AM
Chaos69
Suspension & Brakes
May 3, 2006 04:18 PM
VoltageLS
Aug 25, 2002 11:25 AM
d0nkeyxPunch
Jul 9, 2002 08:13 PM
ragejed
Jun 6, 2002 07:06 PM
