"Suick Change" stut assy.. ..what do I need?
Old Jul 22, 2003 | 05:02 PM
speed racer ferret's Avatar
Default "Quick Change" stut assy.. ..what do I need?
Hi all,
I am thinking about using two sets of struts for my 98 EX.. ..one set of 4 (the factory strut/spring assembly) for wintertime and another set of 4 high-performance ones with lowering springs for the summertime.
I'd like to keep both assemblies intact, in other words as bolt-in units, complete with all necessary hardware so I can just pull out one type and install the other wihtout fiddling around with the spring compressor or swapping parts.
What will I need to make for a complete assembly? I see shock bellows, mounts, and bumpstops for sale on various sites like NOPI but is that it? Do I need a separate bearing or does that come with the mounts?
Thanks very much for any and all help!!
-Trevor
Old Jul 22, 2003 | 05:06 PM
Matt B's Avatar
Default Re: "Quick Change" stut assy.. ..what do I need? (speed racer ferret)
there is no bearing
you need the two rubber bushings and the metal sleve and the washer for the "top hat"
Old Jul 22, 2003 | 05:11 PM
Matt B's Avatar
Default Re: "Quick Change" stut assy.. ..what do I need? (Matt B)
http://www.hondaautomotivepart...ORBER
Old Jul 22, 2003 | 05:46 PM
OK tell me if this sounds like I got it right..
The parts I'd need (per shock) are (2) of part#6, (1) of part#12, (1) of part#5.. ..and the rest of the parts (#7,9) are what come with the 'top hat'?
I take it that part# 10 is what might look like a bellows on another strut and then #s 8 and 13 are the washers for it, and the bumpstop (#11) slides inside of sleeve #10.
Is that about right? sorry for the ignorance but I've never done a strut install on a Honda before
Thanks!
-Trevor
Old Jul 22, 2003 | 06:37 PM
Matt B's Avatar
you need
qty. 1 - 14,5,12,7,9,10,11,13,8
qty. 2 - 6
i got kyb agx struts and they came with the top nut(14) and the rears came with the dust boot and bumpstop (10,11)
the rears also need #6 on the picture below, it stops your spring from squeaking.
fyi, get some extra lower bolts (17) too because they are know to break on hondas.
btw, i have some of those parts from my install if you need them. very cheap.
Old Jul 22, 2003 | 07:49 PM
Hrmm..
send me an email speedracerferret@hotmail.com and we can talk about the parts.
And BTW thanks again!!
-Trevor
jinxd12
Suspension & Brakes
22
Sep 17, 2010 09:57 AM
ityab0y
Suspension & Brakes
12
Jan 6, 2005 09:37 AM
eclecticteg21
Nov 3, 2004 01:16 PM
Briman2021
32
May 19, 2003 06:31 PM
Lo-Buck EF
Nov 17, 2002 05:27 AM
