Easy Turbo Question
Old Jul 22, 2003 | 03:14 PM
OoDepriveDoO's Avatar
Default Easy Turbo Question
Im learnin all this compression ratio stuff... But which would be betta for turbo??
B16A with 10:1
or
B18B with 8:1?
Im under tha impression tha 8:1 would be betta cuz it leaves more room for FI...
Or you could just tell me tha best motor to turbo lol...
Old Jul 22, 2003 | 07:03 PM
Shawn C's Avatar
In The Garage
low compression + high boost = more hp than high compression + low boost
Old Jul 22, 2003 | 07:54 PM
rYduckz's Avatar
Default Re: (22lbGS-R)
8:1 would be better because you can run more boost and that = more hp
if you tried to run as much boost as the 8:1 could but in a 10:1 compression engine detonation will likely happen and you will blow your engine
Old Jul 23, 2003 | 09:13 AM
So what engine should i go with... Whats tha safest low compression engine that you guyz reccomend? reccomend... **** if forgot how to spell recomend...
And should i go with a higher liter engine like a b20 or smaller like a b16?
Old Jul 23, 2003 | 09:23 AM
matt j's Avatar
Default Re: (OoDepriveDoO)
alright do a b18a with 8.5:1 compression, 725cc injectors, 255lph fuel pump, front mount intercooler, cryo treated rods, pistons, crank, (www.cryoscience.com) and then run proper management, i would recommend a full stand alone (i like the apexi power fc with commander) also do some headwork, new profile cams, cam gears, valve springs, retainers, etc. make sure the head can flow some CFMs. Then you can run a stupid amount of boost, just watch your axles because they will break at high boost.
Old Jul 23, 2003 | 09:50 AM
CRXRageD's Avatar
Default Re: (matt j)
damn 8.5:1 is really low. Especially on a Honda. I personally wouldn't go below 9:1. Unless this guy is running extreme boost say 2bar(30psi) I wouldn't bother. The car will be a slug with 8.5 compression.
Old Jul 23, 2003 | 09:59 AM
Hmm... I want a DOHC Vtec Turbo... Now im looking at tha B16B 185 HP or tha B18C5 with 195 HP... Which one would be betta... A high or low liter engine? They both have 10:1 compression...
Old Jul 23, 2003 | 10:46 AM
TwoRedEGgs's Avatar
If you are going turbo, then i would go with like a GSR motor cause it has vtec already and the compression is a little lower the the type R. But any of the motors that have been suggested would make good power with the right components, it's all about the tuning when you want to make power, make sure you get all the right components to make it work.
Good luck man.....
Old Jul 23, 2003 | 10:49 AM
Tha GSR is tha B18C1 right?
Old Jul 23, 2003 | 11:19 AM
matt j's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OoDepriveDoO &raquo;</TD></TR><TR><TD CLASS="quote">
Tha GSR is tha B18C1 right?</TD></TR></TABLE>
yep
Old Jul 23, 2003 | 11:31 AM
Charlie Moua's Avatar
please do search. This topic has been covered many times in the FI form. You read the facts and choose what best suites your needs and driving style ect.
https://honda-tech.com/zerothread?id=542447
https://honda-tech.com/zerothread?id=516794
https://honda-tech.com/zerothread?id=344690
https://honda-tech.com/zerothread?id=304393
https://honda-tech.com/zerothread?id=243123
https://honda-tech.com/zerothread?id=479815
https://honda-tech.com/zerothread?id=354351
https://honda-tech.com/zerothread?id=339387
https://honda-tech.com/zerothread?id=235808
https://honda-tech.com/zerothread?id=202294
https://honda-tech.com/zerothread?id=90082
there are pently more in the archives and in other options of search.... Search is your friend!
Old Jul 23, 2003 | 11:33 AM
**** my fault.. I searched "crx turbo" and "turbo" in tha CRX Forum... I forgot there was a FI forum...
urie2324
Mar 12, 2013 11:56 AM
scspeed
Jul 24, 2008 03:53 PM
Drizzo
Aug 16, 2005 02:00 PM
simoh
Jun 30, 2003 04:25 PM
Muckman
Nov 11, 2001 04:34 AM
