clutch or tranny
here's the situation. it is extremely hard to put it into gear. only time i can put it into gear is when i have to shut off the engine. im thinking it is tranny fluid. other then that i don't know. any suggestions?
thnx for the info guys. i was really hoping it was just the tranny fluid. damn..... im broke now.
just installed koni yellows with itr rear sway
yup tiem for a new clutch. If you can drop your tranny on your own and have the tools to do it then a new clutch should only cost about 350ish give or take 50. However if you can't do this install on your own it cost around 300 for install. I would recomend devoting a weekend to do this install if you aren't that experianced.
Hydraulic clutch?? You don't say what year...
There's a chance that you got air in your clutch hydraulic system. Then when you push down the pedal it doesn't disengage completely, kinda like spongy brakes. Pump the clutch pedal 2 or 3 times each time you wanna shift. IF that improves things, then try bleeding your clutch real good, flushing plenty of fresh fluid thru it.
