Coolant issue?
Old Jul 22, 2003 | 12:09 PM
Goldfingiz's Avatar
Default Coolant issue?
I noticed a hissing sound when I parked my car today. It ended up being the coolant in the coolant resevoir bubbling. When I removed the lid, I noticed there was pressure coming out of the hose, causing the coolant to bubble. It gets VERY hot under my engine bay, but the car wasn't overheating. I had just been driving it for a while, and it felt/ran fine. Temp gauge was normal. Any ideas what it could be?
Old Jul 22, 2003 | 12:33 PM
AzG35's Avatar
Default Re: Coolant issue? (Goldfingiz)
Could be a blown headgasket. Bubbling coolant is usually a sign of that. Do a compression and leakdown to see if it is or not.
Old Jul 22, 2003 | 12:35 PM
Moe's Avatar
Moe
To much pressure, just burp the cap. Put a towel over it, and turn the cap. There is no coolant leaking anywhere.
Old Jul 22, 2003 | 01:22 PM
Goldfingiz's Avatar
Default Re: Coolant issue? (Moe)
Compression is good, i'll try 'burping' it
Old Jul 22, 2003 | 01:31 PM
Moe's Avatar
Moe
You dont have coolant leaking anywhere? You dont smell the sweet smell of coolant while your driving do you?
Check you hoses for cracks, and leaks. You may need a new thermostat, there cheap from the dealer though. So it shouldnt be that big of a problem.
Old Jul 22, 2003 | 04:42 PM
Goldfingiz's Avatar
I got a slight hint of coolant smell, nothing bad at all...
Old Jul 24, 2003 | 05:16 PM
deepstaged's Avatar
DON'T "BURP" THE CAP!!!
On Honda's, they have a breather valve. If you "burp" the cap, it will cause more air to enter the cooling system. Honda's are infamous for overheating with just a small air pocket in the system.
What you want to do is, (while the car is running at normal operating temp) crack the 12mm breather valve open just enough to allow coolant to flow out. Hold your RPM's at 1500 and watch the coolant flow. If you have air in the system, the valve will begin to 'spit'. What you are looking for is a steady stream of coolant. After the stream is established, close the valve (wirst tight) and you are done. If you develop more air pockets in the system, you have a blown head gasket.
The air pockets are most common after a coolant change is performed. Be sure that you have enough coolant in your overflow. Over the next day, keep an eye on the overflow level. The cooling system will pull what it needs from the overflow and vice versa. If you have too much in the overflow, it will spit out what it doesn't need automatically after you shut off the car.
Good luck
Old Jul 24, 2003 | 05:18 PM
deepstaged's Avatar
Oh yeah, the breather valve is normally found near the upper radiator hose on the engine side.
Old Jul 25, 2003 | 09:10 AM
AzG35's Avatar
Default Re: Coolant issue? (deepstaged)
Not all Honda's have the bleeder screw. I know for a fact that 99-00 Si's do not.
Old Jul 25, 2003 | 06:20 PM
deepstaged's Avatar
Default Re: Coolant issue? (AzSi22)
True..
GeneBEllis
May 10, 2013 05:44 PM
Scotty2H
May 3, 2010 08:16 AM
msmithgsr2131
Feb 19, 2006 08:39 PM
Pat
Jan 27, 2002 05:12 PM
Incognito
Nov 19, 2001 03:39 AM
