Inline Pro Headgasket....opinions
Im about to put a revhard 2c kit on my 00 Si. I want to run about 10psi on the street, and around 1bar at the track, so I was wondering what you guys think about the Inline Pro Headgasket. I'll be using Hondata s200 w/boost. Should I wait and save up for Pistons/Rods or do you think the headgasket will be fine (at least for now).
sidenote : I've always been pro pistons/rods build but money has been tight lately.
Thanks in advance.
Thanks in advance.
Inline Pro's headgasket is quality. I'm not sure if they make it in house or not, but what company actually does these days. It's a very good gasket to use, i would buy from them. Especially since you're local, why not.
nu image can get you a head gasket that can customize your comp. ratio.
and it may be cheaper than inline!
call billy at 703-440-8705!
He said that they come in 2MM and 3MM.......i dont know what CR that would bring me to. Im looking to go around 9.3:1 or 9.5ish:1
most of my friends run the 3mm head gasket with stock bottom end (bring a USDM 10.1:1 B18C down to 9.0:1ish) until it blew up then built it. The INLINE headgasket is very good quality. Thats just my opinion.
I love the inline pro 3mm and I am also using their block guard. tops on quality and true testament is that I am using stock ITR bottom end and runnin 11psi daily with no problems as of yet.(knock on wood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR41 »</TD></TR><TR><TD CLASS="quote">I love the inline pro 3mm and I am also using their block guard. tops on quality and true testament is that I am using stock ITR bottom end and runnin 11psi daily with no problems as of yet.(knock on wood)</TD></TR></TABLE>
I use their block guard and headgasket on my R as well and run 10 psi daily....
