Who uses a gasket between the wastegate and turbo manifold?
Old Jul 22, 2003 | 06:52 AM
espanol's Avatar
Default Who uses a gasket between the wastegate and turbo manifold?
Does anyone use a gasket between the wastegate and turbo manifold?I seem to blow these out often.Flamenco -t said he doesn't use one....
Old Jul 22, 2003 | 07:07 AM
oscarmayer's Avatar
Default Re: Who uses a gasket between the wastegate and turbo manifold? (espano(ls))
you should always use one. yes they do blow out, but if you use studs instead of bolts and then use lock nuts or some type that do not back off easly. you with solve htat issue as well as the common loosening of the waistegate issue.
Old Jul 22, 2003 | 07:15 AM
TurboLude97's Avatar
Default Re: Who uses a gasket between the wastegate and turbo manifold? (oscarmayer)
i do and i have one w/ the fire ring, the manifold has studs and i am using a regular washer and a lock washer but a regular nut. I have had no problems with it leaking or comming loose.
Old Jul 22, 2003 | 07:34 AM
espanol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer &raquo;</TD></TR><TR><TD CLASS="quote">you should always use one. yes they do blow out, but if you use studs instead of bolts and then use lock nuts or some type that do not back off easly. you with solve htat issue as well as the common loosening of the waistegate issue.</TD></TR></TABLE>
i use studs on the manifod and the lock nuts don't back off..the gaskets just can't take the heat and burn up....what kind of gasket material do you use..maybe i should copper spray it.
Old Jul 22, 2003 | 07:38 AM
TurboTegB18c's Avatar
I do not run the gasket between manifold and turbo. As long as both the surfaces are true, you shouldn't have any problems with it leaking. Paul
Old Jul 22, 2003 | 07:40 AM
quikB18B's Avatar
My gasket crumbled twice in last summers heat, so i ran it without one and it sealed fine, no leaks. I did continue have bolts back out because of heat expansion, but nothing some more loctite couldn't fix.
Old Jul 22, 2003 | 07:50 AM
Flamenco-T's Avatar
Default Re: Who uses a gasket between the wastegate and turbo manifold? (quikB18B)
if you have flat surfaces on both the manifold and WG, you'll be fine. Clean them up and as it heats up, the metal will expand and the carbon will seal hairline spacing in between the two surfaces.
stan
Old Jul 22, 2003 | 08:06 AM
espanol's Avatar
Default Re: Who uses a gasket between the wastegate and turbo manifold? (Flamenco-T)
ok losers..i'll try it...
Old Jul 22, 2003 | 08:08 AM
Full-Race Geoff's Avatar
dont run the gasket, just make sure both surfaces are decked perfectly flat. Im sure you dont have the downtime available but if you need, send them to me and ill deck them.
btw check out your post count and user rating thats a lot of 9s!
Old Jul 22, 2003 | 08:37 AM
quikB18B's Avatar
Default Re: Who uses a gasket between the wastegate and turbo manifold? (FFgeoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FFgeoff &raquo;</TD></TR><TR><TD CLASS="quote">
btw check out your post count and user rating thats a lot of 9s!</TD></TR></TABLE>
Funny you noticed that Also if im not mistaken isnt the interga a 99 also. How ironic maybe felix is the devil in disguise
Old Jul 22, 2003 | 08:50 AM
b16ahybrid's Avatar
Default Re: Who uses a gasket between the wastegate and turbo manifold? (TurboTegB18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTegB18c &raquo;</TD></TR><TR><TD CLASS="quote">I do not run the gasket between manifold and turbo. As long as both the surfaces are true, you shouldn't have any problems with it leaking. Paul</TD></TR></TABLE>
I dont run one either, no problems at all.
Old Jul 22, 2003 | 08:51 AM
espanol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FFgeoff &raquo;</TD></TR><TR><TD CLASS="quote">dont run the gasket, just make sure both surfaces are decked perfectly flat. Im sure you dont have the downtime available but if you need, send them to me and ill deck them.
thanks for the offer geoff... ...
Old Jul 22, 2003 | 01:32 PM
rioninja's Avatar
My local hardware store sells small sheets of copper for projects and such.
Ive made a few copper gaskets, and never had problems with them blowing out.
You really dont need one like was stated above, but im just
**** about leaks
Old Jul 22, 2003 | 01:38 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Who uses a gasket between the wastegate and turbo manifold? (rioninja)
I dont run a gasket, they suck... as stated above, make sure their nice and clean surfaces, then boost away
Old Jul 22, 2003 | 02:21 PM
silverEH2's Avatar
Default Re: Who uses a gasket between the wastegate and turbo manifold? (SIXTYdashONE)
i used the "fire ring" but i never ran as much boost as u do, i have heard of people not using the gasket.....give it a shot and see what happens
Old Jul 22, 2003 | 02:40 PM
espanol's Avatar
Default Re: Who uses a gasket between the wastegate and turbo manifold? (silverEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverEH2 &raquo;</TD></TR><TR><TD CLASS="quote">i used the "fire ring" but i never ran as much boost as u do, i have heard of people not using the gasket.....give it a shot and see what happens </TD></TR></TABLE>
i only run 11 lbs...how's team teal going?
slowcrxsib16
Jul 4, 2006 09:56 PM
wantboost
Dec 25, 2004 11:11 PM
2000__GSR
Jun 15, 2004 05:31 AM
r7
Sep 24, 2003 11:11 PM
KStuned
Apr 3, 2002 04:08 PM
