fmax turbo on 97 accord
Old Jul 22, 2003 | 04:56 AM
chil1e26's Avatar
Default fmax turbo on 97 accord
hey all, i am new to this forum so bear with me. I have a 97 honda accord with the original engine. I have upgraded a few things on it. I have done most of the work on it so I am somewhat mechanically inclined. however, i am unclear how my turbo kit is to be installed. I bought an fmas turbo kit which utilizes a T3/T4 ceramic ball bearing turbo along with a turbonetics wastegate, bypass valve and so forth and so on. I am not sure where to hook up the oil feed line comming from the engine going to the turbo which allows adequate lubrication? If anyone has a clue please enlighten me. Also, if anyone has an FMAX turbo kit I would like to know how much horsepower you truly are getting. I would prefer someone who has done a dyno. Well, hopefully you guys can help. Thanks
Old Jul 22, 2003 | 05:15 AM
KGAccord's Avatar
Default Re: fmax turbo on 97 accord (chil1e26)
you drill a hole in the oil pan.
you should have found a shop and went custom instead fmax. http://www.trickengineering.com
Old Jul 22, 2003 | 09:01 AM
AccordDriver03's Avatar
That site doesn't have much on their turbo kits. Most of the time its custom kits that go wrong.
If you have the time to invest in troubleshooting, go custom. Or if you are new to the turbo scene. From what I've been hearing get a kit for your first time, after that go custom. So you can get a feel for what's needed.
Besides he already bought the kit.
How much did you get the kit for? And where?
Old Jul 22, 2003 | 09:12 AM
KGAccord's Avatar
Default Re: (AccordDriver03)
[QUOTE=AccordDriver03]That site doesn't have much on their turbo kits. Most of the time its custom kits that go wrong.
QUOTE]
the idea is a good shop knows what they are doing and knows what you need, the fmax kit uses cheap parts except for the turbo and is overpriced. believe me take a look at their custom installs and you'll get an idea of what can be done. one of the partners has a daily driven 12s civic on street tires with just H22+turbo, no internal work. that says a lot.
generally where **** goes wrong is inproper install regardless if it's a name brand kit or custom kit and the use of crappy hardware.
Old Jul 22, 2003 | 09:34 AM
KGAccord is right about the oil return line. You need to drill a hole in the oil pan.
He already bought the turbo. And when all is said and done custom will cost more for the install. I've researched this before. It may be a good shop that you know people from but for a person that is in the market it's rather skeptical if they don't have anything on their site on the components they use.
Labor is always what kills on the bill..
Besides, he already bought the kit
I think FMAX was a good choice for something reliable and proven to work w/ minimal modification.
Modified by AccordDriver03 at 7:22 PM 7/22/2003
Old Jul 22, 2003 | 09:41 AM
booja's Avatar
you donty tap the oil feed line from the oil pan... thats for the return line...
you get the feed from the back above the oil filter i think... or was it below...
cant rememver, but its somewhere around the oil filter.
Old Jul 22, 2003 | 09:43 AM
KGAccord's Avatar
^yes since he already has the kit he's best with that. i guess the idea is to research and check out shops and racetracks to see what everyone has to find out what's good. a stage 1 kit for $2,000 + install doesn't seem bad when you consider fmax kist are in the $3,000 range alone and a stage 1 kit should be comparable to a fmax or drag kit. finding out what that shop will use it's kit is just an e-mail or phone call away too, which is something that alot of people seem to forget nowawdays.
Old Jul 22, 2003 | 03:45 PM
chil1e26's Avatar
I bought the kit for $3300. I figure since this is my first time in experimenting with my accord for power I thought I would go with an already made kit to see how turbo actually works and to get a feel for it. I plan on doing an engine swap. I will be getting an H22a Euro R engine and will be installing a custom made turbo kit. I am currently installing the turbo kit I purchased and found out that I was missing some pieces from it cuz when I recieved the box it was all torn apart. The company told me to just keep what I have and call them and let them know what is missing and they will overnight it to me for no charge. Turbonetics has been pretty kewl with me so far. I looked above my oil filter and still don't see where the darn oil feed line goes. I called the company and they told me it hooks up to the oil pump sending unit but I can't find it anywhere. I have a chiltons but it isn't helping. I was hoping someone online has an fmax turbo kit and could help me out in where they have their oil feed line hooked up to and where the hell is this oil pump sending unit?
Old Jul 22, 2003 | 03:57 PM
97F22B2's Avatar
you tap for feed on the oil sending unit ABOVE the oil filter and weld a bung on the oil pan for the drain. I highly recomend welding it on instead of screwing it on with a gasket.
Old Jul 22, 2003 | 08:56 PM
Where did you purchase your kit from?
Old Jul 22, 2003 | 09:05 PM
iam7head's Avatar
Listen
oil supply-oil sending unit, get a deep socket size 24 to wrench it out.
oil return- tap the fitting as high as possilble or it will give you crap later on.
Old Jul 23, 2003 | 02:06 AM
chil1e26's Avatar
I bought the kit online through the website turbokits.com.
Old Jul 23, 2003 | 12:59 PM
97F22B2's Avatar
listen to 7head, he knows much grasshoppa
Old Jul 23, 2003 | 01:48 PM
Accord94DX's Avatar
just get a golden eagle sandwich feed adapter for your turbo feed. it makes your life 10x easier.
Old Jul 23, 2003 | 03:04 PM
fluxion's Avatar
amin n'rangwa edanea
Default Re: (chil1e26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chil1e26 &raquo;</TD></TR><TR><TD CLASS="quote">I bought the kit for $3300. I figure since this is my first time in experimenting with my accord for power I thought I would go with an already made kit to see how turbo actually works and to get a feel for it. I plan on doing an engine swap. I will be getting an H22a Euro R engine and will be installing a custom made turbo kit. I am currently installing the turbo kit I purchased and found out that I was missing some pieces from it cuz when I recieved the box it was all torn apart. The company told me to just keep what I have and call them and let them know what is missing and they will overnight it to me for no charge. Turbonetics has been pretty kewl with me so far. I looked above my oil filter and still don't see where the darn oil feed line goes. I called the company and they told me it hooks up to the oil pump sending unit but I can't find it anywhere. I have a chiltons but it isn't helping. I was hoping someone online has an fmax turbo kit and could help me out in where they have their oil feed line hooked up to and where the hell is this oil pump sending unit? </TD></TR></TABLE>
if your gonna be boosting anyway i would just get a h22a and maybe just the type r tranny if you have the money, why spend an extra $1500 when the added boost you could get out of the lower compression h22a would more than compensate for the extra 20hp of the type r engine? i would only get a type r engine if i planned on staying n/a and had money growing out of my butt cheeks.
since you plan on swapping the engine out anyway, boost the **** out that f22 and let us know how it turns out.
Old Jul 29, 2003 | 04:58 PM
chil1e26's Avatar
Just to give you guys an update. I found my oil pump sending unit. My turbo kit is now installed and I am very impressed with the outcome. The turbo kicks in between 3 to 4000 rpm and it hits hard. I am pretty happy with what i have done. I have learned quite a bit on installing a turbo kit on my accord and just working on it so if anyone has an questions feel free to ask me. I am no expert but I can pretty much tell you what you need to do and how to do it. Oh yeah, I am having a problem with the cooling of my engine. I am trying to figure it out. I checked my thermo stat and it is good. I have adequete coolant. I am not leaking any coolant into my engine. I am just thinking that I need a higher rating temp sensor and all will be well. If anyone has any suggestions I would greatly appreciate it.
Old Jul 30, 2003 | 04:02 AM
KGAccord's Avatar
try some redline water wetter
Old Jul 30, 2003 | 08:17 AM
How'd you end up tapping the oil pan and oil pump sending unit? Were those the only tricky parts when installing the kit?
Got any pictures of the install? Still trying to decide whether turbo or h22a. I think since I'm in Cali, I'm forced for h22a specifically for smog reasons. Hard to find people to smog now.
From what I hear/reading H22a is smog compliant. But still may add turbo later.
sanitarium
Jul 17, 2005 04:27 PM
tjohnson329
Dec 6, 2004 11:15 AM
GSRwBOOST
May 4, 2002 06:05 AM
TEC2
Nov 24, 2001 01:24 PM
