Installing turbo. DSM injectors OEM Clip.
Well I'm into my install right now, d16y7 w/ 14b. I'm using dsm 450cc injectors, and the OEM honda injector clips. Well I cut the little tab that everyone says you can cut and plug in, and they still dont fit. It really has me stumped, and I dont have the ability to go get other injector clips. Anyone have a solution for me?
Take a long hard look at your injector clips. Then do the same to your injectors. Now compare the similarities and differences. Ask yourself, why/where isn't it fitting? Does it look like I can make it fit? After you do that you should know whether you can make your current clips fit or if you have to get new ones.
you might have to change to obd1 clips. I know i had to because the clips were entirely different on my 2000 gsr. they fit on obd1 clips. just had to slightly modify the injectors. If you do have to buy new clips, just go to autozone or any autoparts store and ask for injector pigtails for a 95 integra. They're about 2 or 3 bucks a piece.
Panoply
Jul 18, 2005 09:36 AM
