Intake manifold differences? WTF? Pics inside of my mystery.
Old Jul 21, 2003 | 12:01 PM
sporkcrx's Avatar
Default Intake manifold differences? WTF? Pics inside of my mystery.
I have two intake manifolds, and as you can see by the pics, one is missing a sensor on the back of it. It's also missing a vacuum plug for the sensor, the bolt holes for it, and there's also another vacuum plug it's missing for the map sensor. This is suppossed to be from an 89 si, same as my car, but my manifold has that sensor on it. Is this a different year? Model? The intake manifold with the sensor is really corroded so I'd rather use the other...but I don't want it throwing a code because of a sensor unplugged. Any clue wtf is going on here? I'm stumped.
Old Jul 21, 2003 | 12:35 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Intake manifold differences? WTF? Pics inside of my mystery. (sporkcrx)
My guess - the on without the vacuum tube and sensor is from an automatic.
Old Jul 21, 2003 | 12:57 PM
sporkcrx's Avatar
Default Re: Intake manifold differences? WTF? Pics inside of my mystery. (4drEF)
That's a very good posibility! Never thought of that. Automatics don't use map sensors? Also, what sensor is that on the bottom left of the mani?
Old Jul 21, 2003 | 01:10 PM
rjardy's Avatar
looks to me that the one on the right is equiped with an EGR system.
Rob
Old Jul 21, 2003 | 01:29 PM
MAD SCIENTIST's Avatar
ooohoooh i know pick me!the sensor thats missing is the fast idle control solinoid.it controls idle at start when engine is cold.the reason why its not there is cause the manifold is off an 88 si.the 88 fast idle contol solinoid is on the fire wall kinda lke the hfs.you dont really need that sensor i didnt hook mine up when i my swap.the motor idles high til its warm then it fixes itself
Old Jul 21, 2003 | 02:38 PM
MrTodd's Avatar
Default Re: Intake manifold differences? WTF? Pics inside of my mystery. (MAD SCIENTIST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAD SCIENTIST &raquo;</TD></TR><TR><TD CLASS="quote">ooohoooh i know pick me!the sensor thats missing is the fast idle control solinoid.it controls idle at start when engine is cold.the reason why its not there is cause the manifold is off an 88 si.the 88 fast idle contol solinoid is on the fire wall kinda lke the hfs.you dont really need that sensor i didnt hook mine up when i my swap.the motor idles high til its warm then it fixes itself</TD></TR></TABLE>
He's right. The one on the right has the fast idle solenoid attached, whereas the left manifold doesn't have it. Either way, you don't need it. Honda did away with the idea later on...
Old Jul 21, 2003 | 03:39 PM
sporkcrx's Avatar
Default Re: Intake manifold differences? WTF? Pics inside of my mystery. (MrTodd)
Sweet, it'll be much cleaner. Yea, my 89 si has that. So if I just leave the sensor electrical plug unplugged it wont throw any codes?
Old Jul 21, 2003 | 04:09 PM
CRXRageD's Avatar
The manifold on the left is an 88 Si manifold. The one on the right is a 89-91 Si.
Whichever wiring harness you have, it will have to be an 88 or an 89-91. I know, the stuff is wierd because the 88 bastard year is missing a plug on the harness, you should be fine either way.
Old Jul 21, 2003 | 05:55 PM
seekerONE's Avatar
Default Re: Intake manifold differences? WTF? Pics inside of my mystery. (CRXRageD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXRageD &raquo;</TD></TR><TR><TD CLASS="quote">The manifold on the left is an 88 Si manifold. The one on the right is a 89-91 Si.
Whichever wiring harness you have, it will have to be an 88 or an 89-91. I know, the stuff is wierd because the 88 bastard year is missing a plug on the harness, you should be fine either way.</TD></TR></TABLE>
exactly what he said
Old Jul 21, 2003 | 06:29 PM
Fred n J_v2.0's Avatar
yup, you wont need it.
Old Jul 21, 2003 | 07:06 PM
FourthGenHatch's Avatar
Default Re:
Does anyone find it odd that even though it doesn't have those sensors it still has basically the same shape it would if it had them. Almost like they anticipated having it, but never did, how weird.
Old Jul 21, 2003 | 07:07 PM
Default Re: (95VXFRANK)
yes u will throw a code under heavy throttle with a cold engine.but itll be fine.please hold your applause til the end of the show.lol!
Old Jul 21, 2003 | 07:49 PM
sporkcrx's Avatar
Default Re: (MAD SCIENTIST)
But under WOT when the engine is warmed up it'll be fine, no code?
Old Jul 21, 2003 | 07:59 PM
Default Re: (sporkcrx)
i haven thrown a code with a warm engine under wot.and no one beatson their car like i do.guys at my job call me redline
Old Jul 21, 2003 | 08:03 PM
Shawn C's Avatar
In The Garage
Default Re: Re: (FourthGenHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone find it odd that even though it doesn't have those sensors it still has basically the same shape it would if it had them. Almost like they anticipated having it, but never did, how weird.</TD></TR></TABLE>
do you supose that JDM ones came with it? just like the 90 SiR motor i bought (B16A), which was off of an automatic. it had the kickdown cable bracket bolted into a spot that was on the USDM B16A2 and 3 IMs, but, of course, there was nothing tapped at these places. just my feeble attempt at a guess......
Old Jul 21, 2003 | 08:07 PM
sporkcrx's Avatar
Is there a plug that connects to it? I took off the rubber boot and it looks like a fitting with frieken glue all over it. I tugged on the bitch but I dont want to rip anything apart. How the hell can I disconnect it to make sure my car doesn't freak out?
Old Jul 21, 2003 | 08:14 PM
Default Re: Re: (22lbGS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22lbGS-R &raquo;</TD></TR><TR><TD CLASS="quote">
do you supose that JDM ones came with it? just like the 90 SiR motor i bought (B16A), which was off of an automatic. it had the kickdown cable bracket bolted into a spot that was on the USDM B16A2 and 3 IMs, but, of course, there was nothing tapped at these places. just my feeble attempt at a guess......</TD></TR></TABLE>
Maybe when they machine these engine parts perhaps they make like one basic manifold, then have it modified for different engines or countries specs or what not.
Old Jul 21, 2003 | 08:22 PM
sporkcrx's Avatar
It's weird how the blank spots are on 88's, so they obviously had it planned out. Then for some reason decided to include them in the later years.
crist488
11
Jul 15, 2011 09:26 PM
sohcvtec91hatch
10
Dec 14, 2006 05:48 PM
v-attack
Jul 16, 2003 01:07 PM
Touch
Jun 16, 2003 07:13 AM
dose
Apr 7, 2003 06:52 PM
