Tie rod Question
Old Jul 21, 2003 | 07:33 AM
Timmah!!'s Avatar
Default Tie rod Question
Well, After diconection my tie rod this time, I notice that the threads on the ball joint were hosed, and the nut will not thread back on. So I need to know if it might be a better idea to just get the entire tie rod, or just try and press in a new ball joint. I can get the entire rod from honda for about 65 and change. Majestic has what they say is the tie rod end, and I dont know if that is just the ball joint or the entire rod. They do not have the entire pice indicated as what they are selling http://www.hondaautomotivepart...E+ROD
I do have a press to do the job, but I would rather just get the the tie rod and replace it. Bellow is a picture with the piece that I want to replace.
Old Jul 21, 2003 | 08:59 AM
keithv's Avatar
Default Re: Tie rod Question (azroth)
just get a whole new tie rod from autozone/pepboys/napa/CAP/etc. they are like $50 or so (per side).
Old Jul 21, 2003 | 09:04 AM
streetlegal gocart's Avatar
Hosed(stripped)? Is it warped? You could try using a die and rethread it. Size 12m i think, but if its too stripped go one size smaller maybe. Could save u some trouble/time.
Old Jul 21, 2003 | 09:12 AM
Timmah!!'s Avatar
Default Re: Tie rod Question (Doctor Zagato)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keithv &raquo;</TD></TR><TR><TD CLASS="quote">just get a whole new tie rod from autozone/pepboys/napa/CAP/etc. they are like $50 or so (per side).
I gave pepboys a call, and they told me that they only carried the ball joint, which was like 35 bucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor Zagato &raquo;</TD></TR><TR><TD CLASS="quote">Hosed(stripped)? Is it warped? You could try using a die and rethread it. Size 12m i think, but if its too stripped go one size smaller maybe. Could save u some trouble/time.</TD></TR></TABLE>
It is gone, I would have rethreaded it if I could have. It is all bent out of shape
Ill give some of the other parts stores later tonight i guess.
Old Jul 21, 2003 | 09:34 AM
keithv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azroth &raquo;</TD></TR><TR><TD CLASS="quote">
napa definitely has the entire tire rod. i got mine there.
Old Jul 21, 2003 | 10:18 AM
90civichbsi's Avatar
Default Re: Tie rod Question (keithv)
i got a couple tie rods Oreilly's for under 40 each when i did my suspension a while back
Old Jul 21, 2003 | 10:32 AM
Timmah!!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv &raquo;</TD></TR><TR><TD CLASS="quote">
napa definitely has the entire tire rod. i got mine there.</TD></TR></TABLE>
Ill give them a call then. Thanks
Old Jul 21, 2003 | 10:52 AM
Brandon Clifton's Avatar
Discount Auto Parts has it for 32.99, and I know you have Discount Auto in WPB, FL. It takes about 20 mins to change the whole thing.
Old Jul 21, 2003 | 11:39 AM
crxtasy_12's Avatar
I just had to change my outter tie rod. I went to autozone and pep boys and they were 29.99 I suggest changing both sides at the same time. Then quickly get an alignment.
Old Jul 21, 2003 | 03:46 PM
Timmah!!'s Avatar
Default Re: (crxtasy_12)
Autozone , I just got back, and I spent 40 on the one that I needed , and 16 on the one that I didn't . So I got both, and am doing the job right the first time. Thanks guys, I owe you all a round of drinks
skipbudlong
31
May 6, 2010 10:21 AM
project-boosteD
Sep 14, 2008 09:26 AM
SVOboy
11
Sep 18, 2005 05:09 PM
rasinhell
May 3, 2005 09:23 PM
