automatic motor into a manual car
just wondering what all is involved into changing out parts on the auto. motor if i was to put it in my manaul car. i found a good deal on a ls motor that was in a 4dr automatic. just wondering what parts have to be changed such as a flywheel, etc.
well no ****, i didn't mean "automatic motor" literally, i meant that it came out of an automatic, and i wasn't sure if i needed to change out the wiring harness or anything different since it came out of an auto.
It's not such a dumb question, if you were 'brought up' on a different make than Honda. Some carmakers use different cams or different fuel or timing maps in the ECM. As far as I know, Integras don't have any hardware differences.
PS... You'll need a flywheel and it's bolts, since the motor from an auto-trans car doesn't have one. It's called a flex-plate and the bolts that mount it to the crank are too short. The bolt holes in the crankshaft itself are the same.
My friend has a 91 ls integra and took a ls motor out of an automatic car, he and to change out the Intake Manifold also, something about vacumn hoses i think.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djrazha1 »</TD></TR><TR><TD CLASS="quote">take a look at the intake manny there might be an extra vacuum outlet that you may have to plug up and thats about it .....
including what jim blake said....</TD></TR></TABLE>
Yea, a couple of things are different.
A/T equipped cars have an EGR system. you're gonna have to address that and there are some extra wires for the A/T in the engine harness.
The IM and maybe EM are different and of course the vacuum lines.
My pat answer for all these issues though, is? Got Helms?
It will answer all your questions.
HTH
HTH
RockLee`
15
Aug 25, 2005 05:23 PM
