Internal/external wastegate question
Old Jul 21, 2003 | 03:06 AM
musclefella's Avatar
Default Internal/external wastegate question
Hi guys,
My Garrett T3 turbo is pretty soon to be upgraded to T3/T4 and i was wandering if it was possible to get rid of the internal wastegate and make it so an external wastegate (Tail/Turbonetics) can be fitted??? They probably have to weld it shut or something.
Anyway what are the benefits of an external wastegate other then more precise boost control??? Should i do it or leave it alone???
I'm aiming for 300 whp when i'm done and i have a h23.
Hope you guys can help me out thnx
Old Jul 21, 2003 | 12:49 PM
prelittlelude's Avatar
actaully the way they cure this is by making a flange on your dowpipe to block the hole after the internal wastegate is removed then you can run any other wastegate externally you wanted to.
Old Jul 21, 2003 | 01:50 PM
Default Re: (prelittlelude)
Great, thnx for the info.
Do you think it's relevant to go from internal to external??? I'm only trying to make 300 hp and not 500 hp or something. I thought external wastegates are a must for higher horsepower???
Old Jul 24, 2003 | 12:46 PM
Default Re: (musclefella)
yes i think its a good idea to go with external, external will allow you to have better boost control and this is especially important if you are boosting low numbers on a nearly stock motor. SOmetime internal wastegates can't flow enough to keep the boost where you want
jamjam
Jun 5, 2006 09:21 AM
xrdriver
May 26, 2005 06:54 AM
Nextelbuddy
Jun 9, 2003 10:13 AM
DA666
Apr 3, 2002 08:12 AM
