Blown headgasket OR burnt rings?!?! check comp test.
Old Jul 20, 2003 | 07:14 PM
ILLA_00LS's Avatar
Default Blown headgasket OR burnt rings?!?! check comp test.
ok here’s the deal..
i did a comp test i'll read comp from driver side to pass.
163psi
60psi
30psi, and after we stopped cranking.. it leaked.. to 0psi
120psi.
now i'm getting WHITE smoke out of my oil breather, and nothing out my exhaust.
also when i remove my oil cap i get the same smoke BUT not as much. the smoke out of the oil breather is thick.. and won't stop till i turn the car off.
what would yall say... burnt rings? or BLOWN head gasket?!?!
Old Jul 20, 2003 | 07:24 PM
intekragsr's Avatar
Default Re: Blown headgasket OR burnt rings?!?! check comp test. (ILLA_00LS)
whats under your oil cap? any milky residue? If there is, is a headgasket/sleeve problem.
Redo the compression test, but this time pour a capful of oil in each cylinder. If the compression goes up, is your rings.
Old Jul 20, 2003 | 08:24 PM
lazerus's Avatar
Default Re: Blown headgasket OR burnt rings?!?! check comp test. (intekragsr)
rings. and probably headgasket.
Old Jul 20, 2003 | 08:37 PM
1bar's Avatar
Default Re: Blown headgasket OR burnt rings?!?! check comp test. (lazerus)
its your rings....i had the same problem took off the head my two center piston rings where gone. To see if it really is your rings...drop some oil and the pistons and then do another comp test. If your comp rises then it is your rings... goodluck
Old Jul 22, 2003 | 12:06 PM
ILLA_00LS's Avatar
Default Re: Blown headgasket OR burnt rings?!?! check comp test. (1bar)
thanx yall
rick_rabies
Sep 15, 2009 03:30 PM
8YourV8
Dec 28, 2006 01:05 PM
streetrcr4life18
May 19, 2004 11:21 AM
Witty
Jul 3, 2003 06:20 PM
F1Spec
Nov 8, 2002 05:57 PM
