OBD II LS swap
Old Jul 20, 2003 | 12:03 PM
wannakno's Avatar
Default OBD II LS swap
I tried searchin for this but no luck I' m puttin a 96 OBD 2 B18B into a eg hatch. I know you can just get an OBD 1 ecu and plug and play, but as for right now thats not an option. Is there any way to use the OBD2 ECU. We need this car running?
Old Jul 20, 2003 | 02:01 PM
wannakno's Avatar
Default Re: OBD II LS swap (wannakno)
anyone
Old Jul 20, 2003 | 02:03 PM
espanol's Avatar
you need an obd1 ecu..
Old Jul 20, 2003 | 07:26 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannakno &raquo;</TD></TR><TR><TD CLASS="quote">but as for right now thats not an option. Is there any way to use the OBD2 ECU. We need this car running?</TD></TR></TABLE>
Sounds like you're pressed for time, better get an OBDI ECU It will be much harder and time consuming to wire the motor up and use the OBDII ECU.
Old Jul 21, 2003 | 08:46 AM
JV's Avatar
JV
Who?
Default Re: OBD II LS swap (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds like you're pressed for time, better get an OBDI ECU </TD></TR></TABLE>
A jumper harness will cost about the same as an OBDI ECU. If you are determined to use the OBDII, contact Kenji here on the board. He can make you a jumper.
Either way your gonna have to spend some $ and wait...
Old Jul 21, 2003 | 09:19 AM
Newman's Avatar
New User
Default Re: OBD II LS swap (JV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV &raquo;</TD></TR><TR><TD CLASS="quote">
A jumper harness will cost about the same as an OBDI ECU. </TD></TR></TABLE>
Realize that if you do make your EG into OBD-2, that you're going to have to run more wires from the engine bay to the ECU and wire up more OBD-2 sensors that would not be found in an OBD-1 car or in an OBD-1 harness. Much easier just to get the OBD-1 ECU, run the OBD-1 parts (injectors, distributor, misc sensors that don't plug in properly) and then you won't run into as many problems.
CR91X
Feb 6, 2008 06:15 PM
b18bme
Apr 26, 2007 08:11 AM
99ekb18b
Apr 15, 2007 09:23 PM
crj_lll
Sep 21, 2006 04:57 PM
1BadDC2
Dec 8, 2003 10:04 AM
